Squeaking sound when clutch is pressed |
Aug 7, 2008 - 12:45 PM |
Enthusiast Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) |
I know there is a guy who started a thread about that but that's for him, not me.
My clutch is about to die. Sometimes it shifts good, sometimes it slips. It's been going like that for 2 months. It can shift perfect for a day, and then if I got WOT or not to far from that, it starts to slip. I can also shift, release clutch pedal and then it still slip as if i was giving gas while being at the friction point. Thing is i realised that when i press / depress the clutch pedal, i hear a squeaking sound comming from the engine bay. I think it comes from my clutch Slave cylinder. I have another one at home that also comes from a 94GT that wasnt squeaking. Any thoughts on that? Should I change it? Or there is no relation between this squeaking sound and my clutch? -------------------- |
Aug 9, 2008 - 11:05 AM |
Enthusiast Joined Apr 23, '06 From Rochester, NY Currently Offline Reputation: 8 (100%) |
mine is doing the same thing. no matter if im entering a gear, or coming out of a gear. it feels like its just when the clutch really grabs that it does just a short squeak.
Aug 11, 2008 - 8:21 AM |
Only happens when i press the clutch, not when depressed.
Aug 11, 2008 - 8:33 AM |
Enthusiast Joined Oct 28, '07 From epworth uk Currently Offline Reputation: 3 (100%) |
Only happens when i press the clutch, not when depressed. a few members on ccuk had this problem and they did a clutch fluid change and rebled and it cured this problem its certainly worth a try -------------------- |
Aug 14, 2008 - 10:58 AM |
Only happens when i press the clutch, not when depressed. a few members on ccuk had this problem and they did a clutch fluid change and rebled and it cured this problem its certainly worth a try rebled? -------------------- |
Aug 14, 2008 - 11:08 AM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
it's the fork that connects to the slave it's a grease point. (if it sounds like the squeak is coming from the tranny area)
Aug 14, 2008 - 11:38 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
QUOTE clutch fluid change is that easy to do? -------------------- |
Aug 15, 2008 - 12:14 AM |
Enthusiast Joined Aug 12, '08 From Grand Rapids, MI Currently Offline Reputation: 0 (0%) |
not sure if this will help but the same problem happened with my mr2 and it was the slave cylinder being a little rusty and squeking when its engaging and disingaging the clutch
-------------------- signature under construction
current cars: 91 Red Toyota Mr2 Turbo (my toy) 90 Toyota Corolla LE (dd, soon to be sold) 94 6th Gen Black ST (my new dd and new toy) |
Aug 15, 2008 - 1:14 PM |
Allright i'll go check all those things
Lo-Fi Version | Time is now: January 10th, 2025 - 3:05 AM |
