need help on how to take the right axle |
Aug 8, 2008 - 10:40 PM |
Enthusiast Joined Mar 17, '08 From Manchester,N.H Currently Offline Reputation: 0 (0%) |
hi i need help on how to take the right axle is been leaking tranny fluid and i want to change the seal but i cant get it to come off i loosen the six bolts and still doesnt come off they told me to use a pry bar and it didnt work have someone ever done this.
Aug 8, 2008 - 11:40 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Did you first remove the 30mm nut holding the axle in on the end of the rotor? One you remove that, you move the hub assembly and the outer shaft should slide out. Once this is done, you get a pryer and pry the axle from the transmission. I think I know what 6 bolts you are refering too, and why would you want to remove those? It has nothing to do with your axle seals.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Lo-Fi Version | Time is now: November 26th, 2024 - 11:23 PM |
