> Uh Oh. Battery dieing?, =\\\
post Aug 9, 2008 - 11:33 PM
cnelson
Joined Dec 11, '06
From New Jersey
Ok, so i installed a new headunit and 4 new speakers today. (30 rms each, headunit puts out 22 rms)
I also have some LED lights hooked up, but i don't think there draining my battery.
Heres the thing. My batter died twice today. First time was when we working on the car. I Had left the key in and the lights turned on to test things out and such. (headunit was on) I had the key in for about 45 minutes to an hour. Went to start the car.. and it wouldn't start. Ok, my friend jumps me.
Than later than night. I was sitting playing with the settings on my radio with the car off but the key in turned to ACC. It had probably been 10 minutes or so, than i went to start my car and same thing. So my friend had to jump me again. Now i believe i may still have the ORIGINAL battery i'm not sure. I can even tell when i go to start the car that it seems to struggle a bit.
My question is; Is this probably because of my new HU and 4 new speakers and such an old battery? OR i did re-wire my LED lights also, could it be a bad ground or something. Would that drain the battery? (keep in mind that i only have 12 LED lights, and two little LED light strips that are being powered and i highly doubt that would drain my battery that quick)
I am going to get a new battery. But does everything think that will fix my problem, or am i looking a bigger problem here?
Thanks for any help.
"Drive Well...
...Drift Better"
post Aug 10, 2008 - 12:31 AM
aflacattack
Joined Jun 26, '08
its sounds like a battery problem...
take a multimeter and check your grounds, then check your battery...
you can always go down to a auto supply store and have your battery checked, like shucks(sp)...
post Aug 10, 2008 - 10:44 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
your battery may have not been fully charged after the first time it was drained. also you may have a bad connection on one of the terminals or your ground so it's not getting the juice it should be to get a good charge on it.
post Aug 10, 2008 - 1:14 PM
cnelson
Joined Dec 11, '06
From New Jersey
yeah, i have a feeling its the battery. i'm going to get a new one, and a volt gauge (which i've wanted for a while) that should put my mind as ease. at least this way i'll be able to tell if its getting low.
"Drive Well...
...Drift Better"
post Aug 11, 2008 - 4:37 AM
trdproven
Joined Aug 2, '05
From Guam
#1 depending on your sounds set up will drain your battery. Is your alternator charging your battery?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 11, 2008 - 4:46 AM
cnelson
Joined Dec 11, '06
From New Jersey
Yes it must be charging the battery because i drove around all yesterday without any problems. I just made sure that if i had the car off that i didn't listen to my music to loud or to long, so i wouldn't drain the battery. I believe i may be over reacting. I'm sure its probably just the battery, its the original battery from 1994 so it's pretty old.
"Drive Well...
...Drift Better"
post Aug 11, 2008 - 5:42 PM
Cutrara
Joined May 6, '05
From PA
Get a YellowTop, they're awesome.
post Aug 11, 2008 - 5:49 PM
cnelson
Joined Dec 11, '06
From New Jersey
ha. I really wanted to, my friend has one.. however my dad and even my friend have concluded that it would be unnecessary and since i'm going away to school next week i need to save ever dime that i can.
"Drive Well...
...Drift Better"
Lo-Fi Version Time is now: November 23rd, 2024 - 10:25 AM
