> 94 celica st puffing blue smoke
post Aug 10, 2008 - 1:11 AM
stryue_19
Joined Apr 12, '08
From St.Paul
hey well i just want to get some of ur opinions about ur car puffing out blue somke? What could the be cause rite now i have no clue why my car is doing that?
leave me some comments on it if you can help me figure it out...thanks
post Aug 10, 2008 - 10:07 AM
96bluevert
Joined Mar 19, '07
From Washington
sounds like your burning oil.
Does it happen continuously while driving or only on start up?
post Aug 17, 2008 - 11:38 PM
TerryE
Joined Apr 27, '08
From Michigan
If it's only at start-up, it most likely the valve seals, it is extremely typical on celica's from 77 at least to the present.
Mine have been doing that since I can't remember. usually after 100,000 miles on the clock. it's nothing major, the seals are cheap, the bugger is pulling the head to get to them and getting the right valve spring compressor (I had to fudge with one from murray's and a hot-glued deep-well socket.) I wouldn't bother unless you using up a lot of oil.
Other than that it could be(oh, my G--. the piston rings, oh no!!!) hope this helps!
post Aug 21, 2008 - 8:46 AM
stryue_19
Joined Apr 12, '08
From St.Paul
QUOTE (96bluevert @ Aug 10, 2008 - 10:07 AM) *
yeah it only happens when i start it up
QUOTE (TerryE @ Aug 17, 2008 - 11:38 PM) *
thanks that does help me to understand the situation now.
post Aug 21, 2008 - 12:22 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I think this is particularly common with the STs. Mine does it too. About 110k on the engine, 237k on the rest biggrin.gif
post Aug 21, 2008 - 1:24 PM
CelicaGTS94
Joined Aug 26, '03
From N.B Canada
my 5sfe has been doing it since I bought it. It had 160,000 Km's when I bought it. It is a known issue with the celica's. valve seals!!
post Aug 21, 2008 - 2:27 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (CelicaGTS94 @ Aug 21, 2008 - 2:24 PM) *
x2
エキサイティングカーレーシングチーム!
post Aug 21, 2008 - 7:30 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
its a known issue with MANY engines as they age and rack up miles.
start adding about 1/2 quart of Automatic transsmission fluid to your oil at oil changes and it'll slowly do two things.
1. clean the engine gently
2. soften and renew the seals slowly.
i no longer have any oil leaks, burn only the tiniest puff on startup, and dont loose more than 1-2mm's off my dipstick between 5000 mile oil changes. though i did also seafoam my crankcase, 1/3 can and 20 minutes idling followed by an oil change.
post Aug 22, 2008 - 5:27 AM
stryue_19
Joined Apr 12, '08
From St.Paul
QUOTE (Bitter @ Aug 21, 2008 - 7:30 PM) *
alright thanks i'll try that.
post Aug 22, 2008 - 12:22 PM
Taskbot
Joined Jun 6, '08
From Hamiltron, Ontario
I'm going to try the auto transmission fluid thing.
Is there any particular type I should aim for or is it all the same ****. I remember when I did my co-op at Acura we had 3 different types that all basically did the same thing but since its my car I don't want to risk putting the wrong **** in.
(\__/)
post Aug 22, 2008 - 12:52 PM
slow_yota
Joined Mar 3, '07
From Sunny Florida
Hmm..Question, Mine doesnt puff blue smoke but at start up it for like 10 secs it will blow white smoke..Is there a big difference ?
post Aug 22, 2008 - 1:12 PM
Taskbot
Joined Jun 6, '08
I think it might be the same thing. I'm almost certain that this is a problem with most 7A-FEs since it was one of the first questions I asked on this forum.
The color thing is pretty moot unless you are blowing a lot of smoke. (than you can see the "color" easily)
A better thing would be to go by smell. If you know what burning oil/burning coolant smells like, let the car sit for a bit to make sure its dead cold... Get in, start it up and slam it into reverse. Back through the smoke that comes out of your tailpipe and inhale.
You shouldn't really need to go to that much effort, but putting effort into redundant things is hilarious.
(\__/)
post Aug 22, 2008 - 9:02 PM
Bitter
Joined Mar 11, '06
its going into your engine, so it doesnt really matter what kind of trans fluid you use. just grab some cheap universal stuff.
post Aug 22, 2008 - 9:12 PM
Remy
Joined Jan 25, '06
From MN
QUOTE (stryue_19 @ Aug 22, 2008 - 5:27 AM) *
Make sure you change your oil within 200 miles after you put in the A/T fluid.
QUOTE (slow_yota @ Aug 22, 2008 - 12:52 PM) *
White smoke is coolant and in rare cases fuel.
"To Protect And To Serve The Wealthy" -POLICE
post Aug 22, 2008 - 11:43 PM
Bitter
Joined Mar 11, '06
nah, you dont need to change again within 200 miles. just run that it for the duration of your normal oil change interval. use some with every change until you notice less smoke burning then use every other change if you feel the need.
post Aug 23, 2008 - 1:48 AM
Por2geezcelica
Joined Aug 17, '08
From NY
so adding a half quart of ATF to the engine will actually benefit it, and stop small oil leak by softening the seals? This wont shorten the life of the motor, or cause damage over the long run will it?
This post has been edited by Por2geezcelica: Aug 23, 2008 - 1:49 AM
post Aug 23, 2008 - 8:47 AM
Bitter
Joined Mar 11, '06
no, its an OLD mechanics trick. trans fluid has additives to keep the countless rubber seals inside the transmission soft and supple for decades on end as well as alot of detergents to keep gunk from building up on the insides of the transmission.
inside your engine it will do the same things, soften old seals and gently clean up gunk. its a pretty common trick to run some atf in with engine oil for a couple oil changes to help quiet noisy lifters on engines.
post Aug 23, 2008 - 6:46 PM
Remy
Joined Jan 25, '06
From MN
QUOTE (Bitter @ Aug 22, 2008 - 11:43 PM) *
I like to flush that stuff out as soon as possible, its like flushing the toilet when your done. smile.gif
post Aug 23, 2008 - 6:55 PM
slow_yota
Joined Mar 3, '07
From Sunny Florida
Well..does this mean i have a BHG then..?
My car isnt overheating since the relay fix...
and it does only do it when i let the sit car for
a while and just right at first.
post Aug 23, 2008 - 7:29 PM
Remy
Joined Jan 25, '06
From MN
QUOTE (slow_yota @ Aug 23, 2008 - 6:55 PM) *
Just keep an eye on your coolant, most likely it is from condensation.
Lo-Fi Version Time is now: November 29th, 2024 - 4:51 AM
