> 1300 mi trip- requirements, yes, its really 1300 miles long trip
post Aug 10, 2008 - 1:13 AM
sameerg85
Joined Dec 26, '07
From oklahoma city
guys i hav a 94 gt, ill be soon goin on a 1300 mi trip, can any one tell me wat all do i need to take care of before i leave, especailly under the hood, i just got new compressor replaced, wat else do i need in terms of plugs and wires check up anything else
I would really appreciate any1's suggestions
thanks
post Aug 10, 2008 - 3:17 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
just make sure your car has been serviced, mainly oil and oil filter, check coolant, brake fluid, power steering fluid. don't worry about spark plugs/leads as they can be replaced anytime, but if you want it running smoother change leads, spark plugs, dizzy cap, rotor.
post Aug 10, 2008 - 3:25 AM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
If it were myself, i would just check up on all my fluids. DEF, change my oil, oil filter, fuel filter, air filter etc. you get the idea. You said that you had just did some maintanaince, well, i would check up on anything I have doubts about. Also check your tire pressure, make sure they properly inflated. Just basic maintanence. Having a number for roadside assistance, or atleast some sort of emergency contact helps, also a few tools incase something happens (maybe you have some modifications that might be suspect to failing, but enough to where you can fix urself without roadside assistance). Flashlights, blankets, of course FOOD and water for emergencies. And finally, cash. Bring cold hard cash incase you need money where there isnt a place to withdraw money. Well GL with your trip and hope you ahve fun...
(\__/)
post Aug 10, 2008 - 8:54 AM
mikew04
Joined Feb 19, '04
From austin tx
Don't forget to make sure your spare tire is inflated as well
post Aug 10, 2008 - 11:13 AM
p0lish
Joined Apr 5, '08
From Warsaw, Poland
get jumper cables and one of those cheap lighter air pumps and you should be set
post Aug 16, 2008 - 5:07 AM
JonMarkos
Joined Jun 13, '06
From Omaha, Nebraska
Two months ago I took my car from Nebraska, to Las Vegas, onto Phoenix, with a final stop in San Diego before going back home. Right around 4000 miles. I changed my oil & filter, changed the air filter, and had my mechanic check the whole car over. Both half shafts later and a timing belt later and I was good to go.
QUOTE (mikew04 @ Aug 10, 2008 - 8:54 AM) *
I also got rid of my tiny spare and have a full size tire on a stock rim sitting in my trunk, I didn't want to be stuck in the middle of the desert on a doughnut.
We shall show mercy, but we shall not ask for it.
post Aug 18, 2008 - 2:32 PM
crimsonchin
Joined Oct 4, '06
From va
a few years back i took my 94 st from va to ca and back. before i left i checked the above stated stuff, only problem i had was my water pump went out on the way back, but i dont think you can really look at them and tell they're about to fail... but if your car has a lot of miles on it and you've never put one on it...
Lo-Fi Version Time is now: December 1st, 2024 - 8:21 PM
