> Different Trannys?, mix and match?
post Aug 12, 2008 - 5:41 PM
wannabealilfaste...
Joined Oct 17, '07
From San Diego
Hey guys i was wondering, do i have to use a transmission out of a 6gc for the tranny swap or can i use one from a different toyota? If so what different toyotas can i use i know solara but what about a 5gc or even a 7gc Gt of course wink.gif camry too a list of tranny swap possibilities would be kinda cool
post Aug 12, 2008 - 6:12 PM
Taskbot
Joined Jun 6, '08
From Hamiltron, Ontario
Depends on the engine however since you're a GT I would aim for something that will hook up to an S engine. So 4G 5G and 6G celis all had S engines. You can also use the transmission from the Camry (5SFE - same engine as yours) and the MR2 (5SFE - 3SGTE) I don't think you can use the transmission from the 2ZZ-GE (7 gen GT)
Hahaha that answer seemed way too simple but I don't know any of the transmission available to you, name wise at least.
(\__/)
post Aug 12, 2008 - 6:23 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Are you in need of a transmission because your current tranny is busted or are you swaping the motor? You cannot use either c56 nor the c60 from the 7th gen celica's. You can use the s53 tranny from the 5th gen gt/gt-s, but they have weak synchros. You might as well source out a s54 tranny if you are on a budget. But if you want a heavy duty tranny get an e153 tranny from a v6 solara or convert an mrt2 turbo e153 to fwd or convert an alltrac e153 awd to fwd. But if you opt to go with the e153 you will need the 3s flywheel, 3s clutch disc and pressure plate. You will also need mr2 inner axles and alltrac outers. Good luck.
94 Celica gt white (sold)
post Aug 12, 2008 - 6:52 PM
wannabealilfaste...
Joined Oct 17, '07
From San Diego
No my tranny isnt bad its just.... auto but i wanna do the swap i know what i need, i was just milling the junkyards yesterday saw a 5gc with a manual tranny and i wondered if it could be used for the swap. Now i know tho that its not a good choice, thanks to you so ill try to look into a solara tranny i was just wondering the options. I was gonna do a 5sfte or a v6 swap but most likely the first one due to emissions.
post Aug 12, 2008 - 8:01 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
QUOTE (wannabealilfaster @ Aug 12, 2008 - 6:52 PM) *
If you are going to do a v6 swap, you might as well do the e153 tranny too. It will cost, but worth it.
post Aug 13, 2008 - 12:11 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (wannabealilfaster @ Aug 12, 2008 - 4:52 PM) *
a v6 would pass emissions easier than a 5sfte. The only benefit is you can remove all the aftermarket stuff when you go to smog it. in either case though, I'd recommend the e-153. when I had the 5sfte, I would have LOVED to have had a e-153.
post Aug 13, 2008 - 2:27 AM
wannabealilfaste...
Joined Oct 17, '07
From San Diego
ok ill go for that one thanks guys
post Aug 16, 2008 - 9:14 AM
tfrock
Joined Jun 2, '08
From Waverly, NY USA
Is the Solara the only one that has the e-153? I was thinking about swapping my auto to a stick too. I have the 7afe but wasn't sure what trannys I could use either.
Lo-Fi Version Time is now: January 9th, 2025 - 1:26 AM
