> Just a heads up for everyone, regarding tires, suspension drop.....etc
post Aug 13, 2008 - 2:24 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
i just changed my tires......the whole set. cuz i ran over a nail on my rear left and staples on my front right kindasad.gif so i asked my dad if i could go half this time as always frown.gif NOT THIS TIME the full set cost'd me 900 not including alignment. got me some Toyo Proxie 4's (partially keepin the TOYO in there wink.gif )SUPER STICKY PERFECT TIRES but costly. when my tires were taken off i have NO THREAD on the inside due to long periods in time going one without proper alignment and close to no thread everywhere else.
so i didnt want all should do. i got alignment with my new tires. only to come to the point from the lead mechanic that they cant get within factory specs. more people say you dont need those alignment kits to get factory specs within a certain drop range. well i have teins on new shocks. i thought i didnt need them.......but now i do.
so this is just a heads up for all you guys. get the alignment kit and get your alignment done and check your tires. be safe be easy LIVE ALOHA biggrin.gif
i still cant believe im still alive also. the mech. also pointed out that my axle nut was loose and can be tightened or loosen'd by hand kindasad.gif upon 3 other things.........so i thank whoever is watching over me.
sorry i dont have pics and stuff. wasnt prepared.........$$ wise and physically when i got this done.
oh yeah now that i have a sort of fixed alignment and new tires i can grip the road way better.
AND DONT USE SPACERS!!!! i took my 5mm off because the contact point of the rim and hub wasnt good. something about the wheel easing its way off the lug bolts and slowly moving the lug nuts off.
post Aug 13, 2008 - 2:35 AM
manphibian
Joined Oct 13, '06
From UK
Good advice, glad you took off the spacers.
A lot of the suspension parts on our cars are OLD. Be nice to them smile.gif
post Aug 13, 2008 - 3:03 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
so i'll be getting an alignment kit and hopefully they car get from -2.0 to atleast -0.6 kindasad.gif its only that stupid camber.
oh i thought this was funny, they had to use the "special lift" to work on my car biggrin.gif barely made on that on too HAHahahahaha
post Aug 14, 2008 - 9:22 AM
Taskbot
Joined Jun 6, '08
From Hamiltron, Ontario
(\__/)
post Aug 14, 2008 - 1:37 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
HAHAHa does living on an island count as a track???
post Aug 14, 2008 - 1:45 PM
DEATH
Joined Dec 19, '07
From tx
That negative camber is half the reason why your car handles so much better after the drop BTW wink.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Aug 14, 2008 - 2:21 PM
bseaman_5
Joined Apr 6, '08
From Overland Park
so you're saying get a camber kit if I'm dropping my car??
post Aug 14, 2008 - 2:23 PM
snapshotgt
Joined Oct 12, '05
From Texas
Camber kits are a must when lowered.
post Aug 14, 2008 - 3:29 PM
DEATH
Joined Dec 19, '07
From tx
Totally if you're worried about tire wear. I've never done it and the only time it comes back to bite me is once a year when I need tires cause the insides are bald and the outsides still show some tread [I tend to wear tires kinda quick tho tongue.gif ]
That said, hardly anyone does.
Edit; Actually wait - When I was lowered on Sportlines I got it to line up within specs at a Toyota shop using their laser alignment machine - so it's not always necessary [That was on a 30K mile 6gc tho and stock struts - which didn't wear out quick either - some of these "musts" are dependant on wear a bit too I think]. But usually.
This post has been edited by DEATH: Aug 14, 2008 - 3:32 PM
EXT: WRC/TRD/404
post Aug 14, 2008 - 4:10 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
well i know im keeping up with most if not all Fwd cars here and just right behind alot of stage 1.5 awd car rolleyes.gif i know imma get some - comments, but its true.
but my main worry now is tire life and getting my damn recon sticker updated kindasad.gif which is gonna be a pain. that's why im getting the alignment kits AND YES THEY'RE A MUST no matter what size drop. cuz the bug will bite and you'll wanna go lower.
to get recon i need an update alignment print out show im almost perfect with fact. specs, full list of parts install currently. also to make sure i have my headlight 22" from the center of the housing to the ground, visible (atleast 2") suspension travel, everything in the engine bay secured like the intake and timing belt cover on stuff like that.
good thing is the guy before me already go recon for my 6gc for rims, exhaust, intake, drop (which wasnt on the car when i bought it mad.gif). also body kits, rims 2" bigger than stock as long as then dont pop out of the fender, spoiler and any other cosmetic enhancements dont require recon but will be noted down for police reasons rolleyes.gif
when my eibach kits comes in i will try to get close to 0 degrees on everything, get my recon, then rework my camber to .754 degrees on all sides with .257 degrees toe in on the front and .35 degrees toe in on the rear.
Lo-Fi Version Time is now: February 13th, 2025 - 6:44 AM
