> Plz help about GT4 Rear Diff, Can a different rear diff reduce Turbo boost?
post Aug 14, 2008 - 10:23 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
Hi guys/Gals...
Am facing a problem:( I had an engine swap, from in my 2000 model Rav4 which i fitted with a GT4 ST205 engine.
Am getting a low turbo boost:( My turbo is
not boosting more than 0.4 bar:(
Do u think its because i havent changed the rear diff? Am still running with my 1AZ-FSE rear diff.
but can a rear diff reduce the turbo boost??
plz help and thnx again bros:)
post Aug 14, 2008 - 4:25 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
you changed the diff? did you just put another one of the same ratio or another one with a different ratio. If its different you will destroy your centre diff (assuming your still awd)
but no changing diff will not change the turbo.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Aug 14, 2008 - 4:28 PM
Taskbot
Joined Jun 6, '08
From Hamiltron, Ontario
Wait, are you saying you put that in a truck?
(\__/)
post Aug 14, 2008 - 5:44 PM
the diff will not change the amount of boost your running.
post Aug 14, 2008 - 5:57 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
The diff shouldn't play any role in how much you are boosting. I recommend you get a diff that cna take the power. Check for boost leaks.
94 Celica gt white (sold)
post Aug 15, 2008 - 3:28 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
yes lol but the truck ur talking about weigh 1282 kg where as the celica weight 1380kg;)
QUOTE (Taskbot @ Aug 14, 2008 - 5:28 PM) *
post Aug 15, 2008 - 3:32 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
QUOTE (Cuts_the_Pilot @ Aug 14, 2008 - 5:25 PM) *
OMG i hope that never happen:(
i will change it to the gt4 rear diff soon
post Aug 16, 2008 - 4:28 PM
DeathWing
Joined Feb 10, '06
From Chile
do a leak test on your intake, its probably becouse you are leaking air, also check your wastegate install , it might be stuck open or something
post Aug 16, 2008 - 7:06 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
dont forget to ground the pink wire that is on the St205 ECU to remove the intercooler fluid level Check engine protection.
post Aug 17, 2008 - 1:06 PM
Rav4Race
Joined Jul 14, '08
From Mauritius
QUOTE (DeathWing @ Aug 16, 2008 - 5:28 PM) *
thnx ill check these:)
QUOTE (domyz @ Aug 16, 2008 - 8:06 PM) *
the pink wire? explain plz
post Aug 17, 2008 - 1:18 PM
lubu
Joined Apr 2, '07
From Great Western Plateau
Are you still using ur W2A setup? If not and you havent ground the pink wire then you're running in safe-boost mode, which is around 5psi I think.
You'll need to ground that wire so that the ECU thinks that the pump is still working, thus allowing you to run full boost mode.
98% completion
aaRon
post Aug 17, 2008 - 1:25 PM
GottaGoTurbo
Joined Jan 20, '07
From England
Have you checked for error codes - the code 54 is the level sensor and will put the engine in limp mode.
post Aug 17, 2008 - 1:30 PM
lubu
Joined Apr 2, '07
Just read ur other thread, seems that youve cleared the 54 code already.
http://www.6gc.net/forums/index.php?showto...p;hl=error+code
98% completion
aaRon
post Aug 18, 2008 - 5:34 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
hehe thnx mate! i read ur post there... yea i think ur right, ill have to change that rear diff asap. and concerning the fuel pump i will soon get the 255lph walbro + sard Fuel regulator. will also change the disk clutch to a single plate exedy. my ignition wires are on ship and should reach together with the clutch. but that rear diff, hmm i really need to do something about it. i will try not to run fast for the time being:(
QUOTE (GottaGoTurbo @ Aug 17, 2008 - 1:25 PM) *
yes bro the codes have been cured.
post Aug 18, 2008 - 5:44 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
yep codes cured...check engine light is off, and ecu is happy:)
but am still unhappy:(
QUOTE (lubu @ Aug 17, 2008 - 1:18 PM) *
yes bro still w2a set up. i will change the rear diff on wednesday and check the wastegate. i will also change the fuel pump...
post Aug 30, 2008 - 12:31 PM
Rav4Race
Joined Jul 14, '08
From Mauritius
Hi am back again. Well ive managed to install the rear diff of the GT4 and i can feel that my car is running smoother. But the boost problem as expected is still persisting:( There are no error codes and ive changed my fuel pump to a walbro 255 lph and added a sard fuel regulator.
Can anyone tell me how much psi i should be running of fuel pressure????
I think the boost problem is because of some kind of leaks that i cant find:( The wastegate did not stuck open. Am boosting like 6 psi actually:(
Does anyone have some kind of tests to check where r the leaks??
plz help
Lo-Fi Version Time is now: November 29th, 2024 - 12:28 PM
