Overheating...., Diagnose my problem? |
Aug 15, 2008 - 12:59 AM |
Enthusiast Joined Oct 25, '07 From los angeles Currently Offline Reputation: 0 (0%) |
Alright 6GC People I need your help...
Today after driving for about fifteen/twenty minutes I parked and noticed that the temp gauge read above the red line and the H. Popped the hood and heard gurgeling coming from the radiator with some overflow. I let it cool down for an hour then came back and drove around the block a couple times. I noticed that the temperature goes through the roof when it starts and slowly climbs. But when i hit about 40mph it cools down to about 3/4 of the way and when i stop it goes straight back up. I had a similar problem like this before and it was a bad water pump which was replaced a few weeks ago. Today there was no coolant on the ground just the few drops that spilled from the overflow. The engine seemed to be running fine and I wouldnt have noticed anything wrong with it unless i looked at the temp gauge. So can anyone help me? Any ideas? I'm stumped. |
Aug 15, 2008 - 1:20 AM |
Enthusiast Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
I think ur fan (or sensor which ultimately responsible for powering the fan anyways) may have fcuked up. Since the engine cools down when ur driving means that the air flowing through cools the radiator and when you stop there is no air flowing through to cool it down hence the rise im temp.
This post has been edited by lubu: Aug 15, 2008 - 1:21 AM -------------------- 98% completion --- aaRon |
Aug 15, 2008 - 5:57 AM |
I dunno....When I get out of the car both are on, but could they be off when i drive?
Aug 15, 2008 - 11:11 AM |
change your thermostat, it's bad.
Aug 15, 2008 - 11:17 AM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
And stop driving it like that until you do change it out.
-------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 15, 2008 - 11:29 AM |
It totally sounds like your thermostat is sticking. The reason it's cooling when you hit 40 or so is because you've got better air flow and that's helping to cool things down some. If that doesn't work, try the radiator cap next; if it doesn't hold pressure, it'll totally overheat on you too.
I know this SUCKS in LA traffic/heat, but if you get stuck overheating, blast your heat, it'll help some with the overheating. Better to be really uncomfortable for a few minutes than risk blowing a head gasket. Also, keep an eye on that water pump - it's possible (not likely though) that it wasn't seated/sealed properly when it was replaced. It could be leaking some but evaporating from the heat before you ever see it drip. Your best bet in this situation if the cap and thermostat replacement doesn't help is to take the car back to where you had the work done and tell them about your problem and what you did to try to fix it. I had this exact problem with my 4Runner when I had the water pump replaced, and it turned out that it wasn't sealed properly and they had to open it all back up again (at their expense, of course) -------------------- |
Aug 15, 2008 - 11:40 AM |
Another theory is that you might have a clog within the engine's block and that stops the water from carrying the heats and dissipates them. If this is the case then even though your fans are on, when stop the temp will still rises up coz the heats are not being dissipate by the radiator and still trapped inside the engine's block, with the car moving the air flowing into the engine dissipates some of the heat and hence the temp returns to normal.
But for your sake I hope the thermostat is bad. -------------------- 98% completion --- aaRon |
Aug 15, 2008 - 2:02 PM |
Is there any way for me to test if the thermostat is working or not? im going to take it to the mechanic monday because they are closed today and the rest of the weekend. By the way thanks for all the responses.
Aug 15, 2008 - 3:13 PM |
Truthfully for the process to test the thermostat, you might as well just replace it, especially since they're so inexpensive. To test it you have to remove it anyway... Do you need tips on how to replace the thermostat?
Aug 15, 2008 - 3:53 PM |
yes please! that would help out alot. thanks
Aug 15, 2008 - 3:55 PM |
Yeah I agree with Griffy - thermostats are cheap and very easy to replace. Just replace it and the cap to be sure and move on from there. Both can easily be accomplished in an hour on the 5S-FE [Not sure what motor you have tho]. Don't pay someone to do this if you can avoid it - I see that being at least $100 bill for $20 worth of parts [IDK - Last time I bought a stock thermostat and cap they were both $5 ea - but that's been a very long time].
This post has been edited by DEATH: Aug 15, 2008 - 3:56 PM -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 15, 2008 - 4:06 PM |
yeah that sounds awesome...i guess i will see if i can swing by the dealer today and pick both those parts up. Yes, its the 5S.
Edit: $66 for the thermostat?! or is that just regular dealership prices? If so anywhere i can get it for cheaper? I need to save as much as I can but cant afford to have my baby off the road for this long. This post has been edited by 95GTCelica: Aug 15, 2008 - 4:21 PM |
Aug 15, 2008 - 5:29 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
OEM thermostat for 95 celica its under oem parts----mechanical----cooling system------thermostat Price:$12.00
www.1sttoyotaparts.com -------------------- "To Protect And To Serve The Wealthy" -POLICE
Aug 15, 2008 - 6:38 PM |
are the cooling fans coming on at all?
Aug 15, 2008 - 6:51 PM |
are the cooling fans coming on at all? QUOTE I dunno....When I get out of the car both are on, but could they be off when i drive?
Aug 15, 2008 - 7:03 PM |
does your coolant smell...well it should smell like coolant. if it smells sickly or like exhaust...not a good thing. -------------------- |
Aug 15, 2008 - 10:43 PM |
Enthusiast Joined Jun 15, '06 From NJ Currently Offline Reputation: 1 (100%) |
radiator fins are probably clogged with debris. remove the radiator and spray the fins with a garden hose
Aug 15, 2008 - 11:24 PM |
does your coolant smell...well it should smell like coolant. if it smells sickly or like exhaust...not a good thing. Yes it smells like it should... I picked up the thermostat today, twenty bucks from the dealer so i figure if i ordered it off the net it would come to about the same. Tommorrow morning I will switch it out. I will also check on the debris in the radiator fins while im there, but i dont know what could be in there. By the way thanks to everyone. This is really helpin me out. |
Aug 16, 2008 - 12:04 AM |
Enthusiast Joined Jul 20, '08 From Columbus, Indiana Currently Offline Reputation: 0 (0%) |
head gasket can be an issue too? if u went past the red u have warped the head and need to replace the gasket and machine the head again. i'm surprised u didn't kill it
This post has been edited by Renegade: Aug 16, 2008 - 12:06 AM |
Aug 16, 2008 - 10:34 AM |
Seriously don't forget to change the cap too. Alot of cooling issues are traceable to that seemingly insignificant part [Some that act just like yours is]. The cap holds back a certain predesigned pressure. as it wears out the seal starts to fail and the pressure is reduced sending the coolant to your overflow and ultimately out on the road.
Just change it too to eliminate that from the equation. And read the post before mine - stop driving it hot before you warp the head and cause yourself worse problems. -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Lo-Fi Version | Time is now: November 25th, 2024 - 11:42 PM |
