4age > 7afe, Swap Questions. . . . . |
Aug 16, 2008 - 12:22 AM |
Enthusiast Joined Mar 3, '07 From Sunny Florida Currently Offline Reputation: 18 (91%) |
So i have my 4age in hand..Ive read that the 7afe tranny will bolt right up to my 4age.
My concerns.. Is this pretty much a plug & play swap..electronically speaking? Will the mounting points concern me at all ? What is the exact stock hp on a 4age ? [im seeing quite a few dif numbers] Can i still use my aftermarket 7afe header on my 4age ? Thanks for any help =] -------------------- |
Aug 16, 2008 - 9:59 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
1. Definitely not plug and play, you need a full wiring conversion: http://www.phoenixtuning.com/
2. Mounting points are the same. 3. Which version of the 4AGE is it? 4. It's possible that the 7A header will fit, yes. Also you're going to need a power steering reservoir and a new high pressure line (and feed lines), and custom a/c lines if you want a/c. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Aug 16, 2008 - 1:37 PM |
1. Hmm..wow. i didnt know that.
2. = good deal 3. i cant tell..the valve cover has no paint or anythign on it..just bare steel. 4. = lets hope so.. I could care less for a/c..so Hmm.. My uncle is the lead tech at a chevy dealership.. Is this a swap that he "should" be able to handle.. Or is the electronicals pretty hard to get right ? -------------------- |
Lo-Fi Version | Time is now: December 4th, 2024 - 7:05 PM |
