> My 7AFE t-vis technical tread, Info on a very scarce motor
post Aug 18, 2008 - 4:51 AM
Ewie
Joined Jun 10, '08
From South Africa
I couldn't find any info on these motors so I started my own info thread as I stripped mine.
http://www.tolken.co.za/twincamforum/viewtopic.php?t=30670
AE82 1600 Twincam (Series1)
Current 7AGTE 16v project
post Aug 18, 2008 - 6:48 AM
DEATH
Joined Dec 19, '07
From tx
Never had a clue these existed. What cars did they come on, ours? What's the numbers these run stock? Sounds like a great motor for what you have planned.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Aug 18, 2008 - 7:43 AM
Ewie
Joined Jun 10, '08
From South Africa
QUOTE (DEATH @ Aug 18, 2008 - 6:48 AM) *
I didn't know they existed either.
Bought it from a local importer as I wanted a 7AFE block.Only when I got home I saw the vacume pipes and unknown sensors.Started searching for info but couldn't find any info.If anybody have info thats not covered in my thread yet please share it here!
post Aug 18, 2008 - 7:03 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
pretty much, its the same 7afe just with tvis. neat, but the intake ports end up being a tiny bit smaller than the non tvis 7afe intake ports. or so i've read.
post Aug 18, 2008 - 8:21 PM
Ewie
Joined Jun 10, '08
From South Africa
QUOTE (Bitter @ Aug 18, 2008 - 7:03 PM) *
Well I'm still to strip the intake from the head.Judging from the outside the intake ports seems quite big but I'll strip it in the week and post more pics with measurements in that thread.
post Aug 18, 2008 - 9:33 PM
Bitter
Joined Mar 11, '06
i read up on them on a australian site, the size of both ports ended up being a little smaller than the single intake port on the non tvis.
post Aug 19, 2008 - 3:59 AM
Ewie
Joined Jun 10, '08
From South Africa
QUOTE (Bitter @ Aug 18, 2008 - 9:33 PM) *
In that case it sould be more torquey on low to midrange.This motor of mine was on a Automatic tranny so I guess it was a good combination.
I'll be stripping the head soon and will post the pics and total sizes in my tread on the TwincamForum as theres still alot to be discovered bout this motor
post Aug 19, 2008 - 8:07 AM
DEATH
Joined Dec 19, '07
From tx
For a low boost application I could see where this would be beneficial altho I've always been a fan of the T-VIS system anyway.
EXT: WRC/TRD/404
post Aug 19, 2008 - 7:23 PM
Bitter
Joined Mar 11, '06
QUOTE (Ewie @ Aug 19, 2008 - 3:59 AM) *
i think that motor would play nicely with some mild cams. little more duration and lift to help it breath, toss on an ebay header, and get a decent a/f tune. you should be able to put down what some 4age's put down.
btw, that engine is OBD2, hence the fixed timing and crank sensors.
post Aug 19, 2008 - 11:30 PM
EXXX_AE86
Joined Jun 30, '08
From Montreal
Hey man do you know if the block is any different then the regular 7afe? also are you going to be putting the 20v head on it? Cause i am very interested in making a 20v 7age turbo for my AE86. I have a 16v waiting to get rebuilt for now but i'm saving up for the big 7agte project. What are you planning on doing with you tvis 7afe?
post Aug 20, 2008 - 12:39 AM
Ewie
Joined Jun 10, '08
From South Africa
QUOTE (Bitter @ Aug 19, 2008 - 8:23 PM) *
post Aug 20, 2008 - 12:45 AM
Ewie
Joined Jun 10, '08
From South Africa
QUOTE (EXXX_AE86 @ Aug 20, 2008 - 12:30 AM) *
I'm going to use my Bigport 16v head.
The block looks exactly like the normal 7AFE block.The section where the crank angle sensor fits is on the oilpump.
The head can take a "normal" adjustable distibutor.
I just bought the 7AFE because I wanted the block and its internals as I want to build a 7AGTE.Only after I bought it I discovered it have tvis on it rolleyes.gif
post Aug 20, 2008 - 10:09 AM
EXXX_AE86
Joined Jun 30, '08
From Montreal
how much did you pick up the engine for?
post Aug 20, 2008 - 2:29 PM
Ewie
Joined Jun 10, '08
From South Africa
QUOTE (EXXX_AE86 @ Aug 20, 2008 - 10:09 AM) *
Don't know what the currency is at he moment but I paid 4500 South African Rand for it which is quite reasonable around here.
post Aug 20, 2008 - 2:38 PM
EXXX_AE86
Joined Jun 30, '08
From Montreal
QUOTE (Ewie @ Aug 20, 2008 - 2:29 PM) *
Well $1.00 Canadian is R8.27 so i guess u paid like 550$ Canadian for it. thats about the price here. maybe i can get one 100$ less or so. But besides the censor on the block there are no other oil passage holes drilled in the block for the T-VIS?
post Aug 20, 2008 - 7:26 PM
Bitter
Joined Mar 11, '06
QUOTE (Ewie @ Aug 20, 2008 - 12:39 AM) *
http://en.wikipedia.org/wiki/OBD_II
post Aug 21, 2008 - 1:46 AM
Ewie
Joined Jun 10, '08
From South Africa
QUOTE (Bitter @ Aug 20, 2008 - 8:26 PM) *
post Aug 21, 2008 - 1:51 AM
Ewie
Joined Jun 10, '08
From South Africa
QUOTE (EXXX_AE86 @ Aug 20, 2008 - 3:38 PM) *
Theres no difference on the block.
The tvis works like on the 4AGE (series1&2) with vacume from the intake to open and close and gets a electrinic signal from the ECU to do that.
There's no sensors extra sensors on the block either.The oilpump is a bolt on so the crank angle sensor is not realy mounted to the block and the Combustion temp sensor is on the head not the block.
post Sep 16, 2008 - 8:59 PM
Ewie
Joined Jun 10, '08
From South Africa
Some extra info and pics added on page 2 of the link regarding the intake tvis plate and fueling.
http://www.tolken.co.za/twincamforum/viewt...p=469673#469673
post Sep 17, 2008 - 7:29 AM
Bitter
Joined Mar 11, '06
see what i mean about the non tvis port being larger than the tvis ports? though i'd love if you measured and figured area to see if its any real difference.
Lo-Fi Version Time is now: November 27th, 2024 - 11:16 AM
