> Rear speakers
post Aug 18, 2008 - 4:28 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
I just finished installing my 6.5" phoenix golds in the doors, was pretty easy, a little custom work, the how-to on here was very useful. Now the rear I thought were 5.25". But after tearing apart all the rear panels to get to the rear speakers, I found the new speakers were a smaller than the stock. I measured the stock speaker and it is 5.5" diameter, which doesnt make sense cuz I dont think there are such thing as 5.5" speakers. Anyone know whats going on here?? Help me out please.
BTW: I have the 4-speaker system.
thanks
post Aug 18, 2008 - 7:54 PM
mikecelica
Joined Jan 31, '07
anyone?
post Aug 18, 2008 - 8:01 PM
Nick205
Joined Aug 17, '08
From Atlanta, GA
I just replaced the speakers in my 95 ST and the front and rear speakers were both 6.5". The front I had to do a little work to get them to fit but the back ones just screwed right into the stock bracket.
post Aug 18, 2008 - 8:11 PM
mikecelica
Joined Jan 31, '07
hmm thats weird, the rear stock speakers look alot smaller than the fronts... I'll take off one of the front ones and try and see if 6.5"s will fit in the rear too. thanks
This post has been edited by mikecelica: Aug 18, 2008 - 8:12 PM
post Aug 18, 2008 - 8:23 PM
Nick205
Joined Aug 17, '08
From Atlanta, GA
Both the front and back are 6.5" speakers however the front ones have a large metal ring around the speaker so it will fit in the 8" speaker bracket.
post Aug 19, 2008 - 3:53 PM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
pix always help us to help u too!
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Aug 19, 2008 - 8:29 PM
mikecelica
Joined Jan 31, '07
Yup for sure they are not 6.5" in the rear. They are 5.5" and I had to make a custom bracket to hold them from wood. Its pretty weird I dont think theres even such thing as 5.5" speakers. Anyone else have this? kindasad.gif
post Aug 19, 2008 - 8:40 PM
Nick205
Joined Aug 17, '08
From Atlanta, GA
hmm that is weird cause like I said I just replaced mine saturday and the 6.5" just fit right in the stock bracket no problem.
post Aug 21, 2008 - 12:08 AM
Por2geezcelica
Joined Aug 17, '08
From NY
so a 6.5" speaker is a direct replacement for the rear speakers and will screw right in the existing bracket? What work needs to be done to get a 6.5" speaker to replace the door speakers?
This post has been edited by Por2geezcelica: Aug 21, 2008 - 12:08 AM
post Aug 21, 2008 - 6:31 AM
Nick205
Joined Aug 17, '08
From Atlanta, GA
You have to make a custom bracket. There are several posts on this forum that show how to do it.
post Aug 21, 2008 - 8:57 PM
Por2geezcelica
Joined Aug 17, '08
From NY
even for the rear speakers? I know the fronts need custom brackets, but the rears need ones too? Got any links to the posts on how to make the brackets?
post Aug 21, 2008 - 11:10 PM
mikecelica
Joined Jan 31, '07
Check the Interior/Audio/Electrical/Wiring sticky for making brackets for the front, the back depends, yours might be direct 6.5" replacements or some weird size like mine which Im guessing noone else has then you have to make something up yourself.
post Aug 22, 2008 - 12:49 AM
brthrurik
Joined Mar 24, '06
From Aloha, Oregon
I had 6.5 in the rear placements, but recently upgraded to 6x9 with a custom bracket and some trimming...
post Aug 23, 2008 - 12:29 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
6.5 in my rears as well. fit like a glove.
post Aug 25, 2008 - 4:37 AM
LastOfTheSTs
Joined Aug 14, '08
From London
Hey Guys,
I'm also looking to update my speakers. As Mike found the fronts were no problem, 6.5" mid's fitting in nicely (I used a pre-bought adapter from eBay rather than modding the existing housing) but when looking at the rears they seem to be 5.5" speakers rather than the 6.5" I was expecting.
This is only the physical measurement of the speaker, i've not taken the panels off to actually measure the fitment. I have a photo of the speaker - can some one let me know what they use to upload and share images?
Will a 6.5" speaker fit directly in, or will I need a mounting adapter?
Thanks
LST
post Aug 25, 2008 - 4:43 AM
manphibian
Joined Oct 13, '06
From UK
Use photobucket.com to host your pics. then paste the [img] code into your post.
The exact size in the back is 16cm, these are pretty rare, but you can find them, i found some pioneers on ebay.
6.5" is about 16.5cm, so you should be able to squeeze them in without too much trouble.
post Aug 25, 2008 - 8:48 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
they should fit directly in unless they are different in Europe. I've put them in 2 celis now. One was my 97 ST and the other my 99 GT.
post Aug 25, 2008 - 10:55 AM
LastOfTheSTs
Joined Aug 14, '08
From London
Hey.
So i've set photobucket up (thanks manphibian) and here is the image.
The JBL speakers I was going to use come with moutning rings which will fit the speaker into a 6", 6 1/4" or 6 1/2" space which is pretty handy for odd size holes. I just didn't want to buy them if they weren't going to fit.
Like I say the measurement is just of the speaker, not the actual mounting spacing so it could be that the aftermarket speaker will drop straight in there no worries.
LST
post Aug 25, 2008 - 6:00 PM
mikecelica
Joined Jan 31, '07
It wont drop right in, trust me I just did it on mine, you need 5.25" speakers. The place where the old speakers are attached to you need to get the old bracket draw it on a piece of thin wood and cut it out and then draw your new speaker on the inside, cut them both out and thts it. Kinda hard to explain but once you take it apart you will know what i mean.
post Aug 26, 2008 - 11:07 AM
SupaGoat
Joined Aug 2, '08
From London, UK
thanks for the info
This post has been edited by SupaGoat: Aug 26, 2008 - 11:11 AM
Lo-Fi Version Time is now: February 23rd, 2025 - 6:29 PM
