> need some help
post Aug 19, 2008 - 9:36 PM
cwlevie21
Joined Jan 14, '07
From Little Rock, AR
So my engine is done for. frown.gif I am here to ask what would be better/cheaper? To rebuild it or to buy one from a local junk yard? Thanks.
post Sep 10, 2008 - 10:27 AM
Davis_2
Joined Sep 8, '08
From Ireland
Sorry to hear about your engine man nothing worse. All depends on the engine i would advise ringing a few companies to get a price because with a junk yard its all down to luck could get a grand enginen or just end up wasting money. What type of engine do you have if you don't mind me asking.
post Sep 10, 2008 - 10:34 AM
D-Man
Joined Jan 18, '08
From Houston
If the junk-yard will show you the test, i'd do it from them. It's easier and less to screw up laugh.gif I'm not sure how much it'd be to do a rebuild on one of our engines. I've never done one of ours. I know for a fact, that if you're swaping block for same block, It's a one day job with everything on-hand.
Damn D-Man - most impressive.
post Sep 10, 2008 - 10:43 AM
DEATH
Joined Dec 19, '07
From tx
Kind of depends what all is wrong with your engine and how much of a rebuild/build up you want to do. If you just want a stock engine I'd say go for a low mileage junkyard engine and change the timing belt, oil pump and water pump at a bare minimum.
Let us know what happened and sort of what your money situation is like.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Sep 10, 2008 - 10:49 AM
D-Man
Joined Jan 18, '08
From Houston
^ usually a pretty good idea to do plugs and injectors, as those items are usually not guaranteed. (niter is the distributors most of the time... kindasad.gif )
post Sep 10, 2008 - 11:01 AM
AE102
Joined Sep 1, '08
From Chester,UK
go for something with warranty. i was recently selling a low mileage 7a out of a GXi i wrote off - then i came across another GXi which i've bought for a project. i swapped the engines over and she fired straight up but the headgasket was blowing slightly - good job i didnt sell it!! the gasket had gone brittle as the engine had been out of use for a while - not a big problem but if i had just bought the engine i wouldnt have been pleased. i pressume its bottom end being a 7a?
Lo-Fi Version Time is now: April 23rd, 2025 - 6:18 AM
