![]() Enthusiast ![]() ![]() ![]() Joined Jan 31, '07 From Ontario, Canada Currently Offline Reputation: 1 (100%) ![]() |
My car was lowered on tanabe df210 lowering springs. After they were installed I got the car alligned at a Toyota dealership. Now still whenever Im turning the steering wheel theres this popping clunking sound. You can hear it more at a stop and your turning the steering wheel, anyone had this before? It wasnt like this before I had the springs replaced.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) ![]() |
crap im blanking as to what it is. but i know that you should replace your shocks as well, u might blow your org.s
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 16, '07 From BP, MN Currently Offline Reputation: 7 (100%) ![]() |
Frequent question to ask......people are going to say that the springs needs to sit in their grooves before the poping goes away.....Otherwise check for any loose bolts with the strut. As well in my stupidity....check for any missing lug nut that can cause a scratching/clicking noise every rotation of the wheel. I had two missing lug nut and I didn't even know it and I thought I had spring issues.....only way to tell in my case is to lift the car and check to see if the wheel/rotor wobbles.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
http://www.6gc.net/forums/index.php?showto...9&hl=spring
There is an arrow on the strut, this needs to point outwards or the spring will make that popping noise.... ![]() ^ did you check this? -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) ![]() |
x2 with the arrow. I was getting this same problem until I took out the assembly and noticed it was pointed the opposite way. Fix this and I guarantee if will fix your problem.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
hmmm side effects..............
you'll wanna go lower ![]() ![]() -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Lo-Fi Version | Time is now: February 18th, 2025 - 8:38 PM |
