Enthusiast ![]() ![]() Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) ![]() |
Well from what i understand a 7A-FE has valves spaced around 22-degrees apart from each other and thats considered pretty good for racing, and the main obstacles are the Ports, Shrouded Valves, crappy Intake Manifold, the cam profiles and a weak undercarraige. Well my question is wouldn't the head work be fine with a good port, Polish, valve job and maybe some re-grinded Higher Profile Cams? and wouldnt some forged Con Rods and Stronger pistons do the job for strengthening the under side? I suppose it comes down to money, time and resources then wouldnt it?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) ![]() |
wat is the question here....
![]() where are u in cali? This post has been edited by CelicaST_CALI: Aug 22, 2008 - 12:43 AM -------------------- BANNED. for life, you moron.
LOL i totally forgot that part i meant to ask would the 7A-FE be able to produce High HP in NA form? and would it even be worth it? Im in the LA area no. and if you have a GT, you dont have a 7a, you have a 5sfe. -------------------- Former Team 5SFTE pro member ;)
Lo-Fi Version | Time is now: February 23rd, 2025 - 4:07 PM |
