My 98 GT's been acting wierd, Engine starts and stops |
Aug 22, 2008 - 12:41 AM |
Enthusiast Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
everytime I start my car it'll start but the RPM's will quickly drop and it'll turn off, however if I rev my engine usually around 2.5 to 3 RPM's it'll stay on but i notice a puff of White Smoke from the exhuast and it only puffs after i Rev? Any ideas what it might be?
Aug 25, 2008 - 4:57 PM |
Enthusiast Joined Jun 18, '08 Currently Offline Reputation: 3 (100%) |
White smoke means the piston rings are done. Blue smoke is burning oil. Yes? No?
Aug 25, 2008 - 5:40 PM |
Enthusiast Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) |
White smoke means the piston rings are done. Blue smoke is burning oil. Yes? No? Yes. White smoke also means preston is burned in the process So could be gasket as well This post has been edited by reko: Aug 25, 2008 - 5:40 PM -------------------- |
Aug 25, 2008 - 5:41 PM |
Enthusiast Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
i think your headgasket is in need of a change. White smoke is engine coolant.
This post has been edited by Rayme: Aug 25, 2008 - 5:41 PM -------------------- -Rémy 02 SiR, 08 250R |
Aug 29, 2008 - 7:46 PM |
White smoke means the piston rings are done. Blue smoke is burning oil. Yes? No? really? it's not a constant stream its a single puff, it only does this when i start the car. there hasn't been any sign of smoke while driving. and oil levels are good to. it's white smoke though |
Aug 30, 2008 - 5:30 PM |
you mean while your car is warming up? it pushes out white smoke then goes away once you hit full operational temp?
Aug 30, 2008 - 5:33 PM |
You probably need to clean or replace your Idle Air Control valve. Besides that, your car is fine.
This post has been edited by lagos: Aug 30, 2008 - 5:34 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 31, 2008 - 3:06 PM |
Enthusiast Joined Aug 29, '07 From San Diego Currently Offline Reputation: 0 (0%) |
I have the same exact problem on my 99 GT WTF????
Sep 1, 2008 - 11:30 PM |
you mean while your car is warming up? it pushes out white smoke then goes away once you hit full operational temp? Kind of, the Smoke only last for a second, like there was unburnt particles left in the Manifold, it has a sulfer kind of smell to it to, but after that 1st puff it stops smoking. and it has rough starts in the cold thats usually when it pushes out the most smoke |
Sep 1, 2008 - 11:34 PM |
Sep 2, 2008 - 11:15 AM |
I heard its common among these engines but no one has said what the cause is...
Sep 3, 2008 - 11:42 AM |
Enthusiast Joined Jul 14, '08 From St. Louis Currently Offline Reputation: 2 (100%) |
my 99 gt recently started to puff once in a while when starting too. it never dies though. it seems like it is normally only after its been sitting a while +10hrs. I'll have to pay closer attention to the color and smell. Im pretty sure its more white than anything, and no noticeable smell.
This post has been edited by jimmykay: Sep 3, 2008 - 11:42 AM -------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
Sep 3, 2008 - 12:40 PM |
Enthusiast Joined Aug 2, '07 From las vegas Currently Offline Reputation: 0 (0%) |
my 94 st had somewhat the same problem. RPM would just drop and car would die but would start back up if car was moving. Never figured out what it was, even after hooking up every scanner/scope available.
Sep 3, 2008 - 12:54 PM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
everytime I start my car it'll start but the RPM's will quickly drop and it'll turn off, however if I rev my engine usually around 2.5 to 3 RPM's it'll stay on but i notice a puff of White Smoke from the exhuast and it only puffs after i Rev? Any ideas what it might be? I've heard of changing spark plugs to be a solution, but not guaranteeing it's your problem. It's because sometimes the seal on the plugs go bad, and allows oil to leak inside the combustion chamber. Sometimes you can burn such a small amount of oil that it appears white. What does it smell like? "Charred-ass" smell would be oil, coolant usual doesn't have that room clearing smell, as it's mostly water. This post has been edited by D-Man: Sep 3, 2008 - 12:56 PM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Sep 5, 2008 - 4:44 PM |
Enthusiast Joined Oct 11, '05 Currently Offline Reputation: 0 (0%) |
I think I have the same problem ... I have a 99 GT and it only happens from a COLD start ... i don't know that that helps anyone in diagnosing the problem but it is much the same .. if I have ran my car in the last 3-4 hours I normally have no problems starting it ... spark plus are OK ... cleaned throttle body before and that helped alleviate the problem for a while but it comes back in a couple of months ...
Sep 11, 2008 - 12:43 AM |
Well i fixed the starting and stopping problem. So i replaced the spark plugs and cables and noticed that Plug number 2 had the spark plug wire core stuck to the spark plug. after changing them the car no longer turned off. however after sitting for awhile it still pushes a small amount of smoke out?
Sep 11, 2008 - 12:52 AM |
probably valve seals if a little smoke out the back with start up.
Lo-Fi Version | Time is now: January 11th, 2025 - 8:53 PM |
