> ABS Sensor
post Aug 22, 2008 - 1:21 AM
kamax
Joined Apr 29, '03
From lynn,ma
so i tried taking out my ABS sensor on the right passenger side and it snap apart... the sensor was stuck in there and i tried a lil force and i guess it was too much and snap.. Is there anywayz to get it out? like some kinda lubicate or would it be best to try and drill into it and just try to pull it out. oh and anyone know how much it would cost for a new one... curently my ABS is not working and I was looking for ways to fix it... hench the cleaning in the first place lol.
any help would be appriciated thanks
post Aug 28, 2008 - 5:47 PM
94TRDcelica
Joined Feb 4, '08
From UK
Just dig it out mate! Drill a hole, pick at it, pull all the wire out and scrape all the plastic out then buy a new one (They ain't cheap) I paid £60 of ebay for one recently!
Then refit it but make sure its an easy smooth fit, if not get some sandpaper around a scredriver or similar rod and scrape away at the inner wall of the mount until the sensor fits flush! Then use coppa slip to pop it in and tighten - easy!!!
Good luck!
post Aug 28, 2008 - 6:47 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
well just so happens 96 camrys (dont know if you have them over there) run the same type of sensor with the only difference being the angle of the wires commign out of it...on the 205 it was no problem and fixed my abs. take whats left of your sensor to a wreckers and look around mid 60's model toyotas for a similar speed sensor.
you will need to cut the wires close to the sensor because the hard lines follow the shape of the guard and chances are whatever car you get the sensor from will have a diff inner guard shape then your 6gc.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
Lo-Fi Version Time is now: November 23rd, 2024 - 7:09 AM
