Enthusiast ![]() ![]() ![]() Joined Jun 21, '07 From SoCal Currently Offline Reputation: 0 (0%) ![]() |
k so when i was takin auto tech we had a comp that told us what we needed for our cars
when i dont have a celica manual i think the comp said it was 4.1Quartz of oil can anyone confirum? |
till its full.
![]() Enthusiast ![]() ![]() ![]() Joined Nov 23, '07 From Houston TX Currently Offline Reputation: 0 (0%) ![]() |
5.
are u guys sure......
im pretty sure it wasnt 5.... |
it says 4 and some change. it will take 5 just fine
its ~4.5
too much oil is just as bad as too little, just FYI. -------------------- Former Team 5SFTE pro member ;)
I always change mine and put 4 in it.
I keep a 5th bottle for topping off later on. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Enthusiast ![]() Joined Aug 17, '08 From NY Currently Offline Reputation: 2 (100%) ![]() |
what about for a 7afe? Is it 4 quarts?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
YOu put until you can measure it is full on the dip stick, you can never say 4, 4.5 or 5 because you will never drain the oil exactly the same every time. YOu put 3.5 quarts first, turn on the car for a few minutes, turn it off and let it sit for some time. Check again the dip stick and fill remaining accordingly. I have the manual and this method is by the book.
This post has been edited by trdproven: Aug 24, 2008 - 7:28 PM -------------------- 94 Celica GT
open fill cap
drain oil remove filter install drain plug install filter install 4 quarts of oil replace fill cap start engine for 20 seconds turn off engine wait 5 minutes check dipstick add oil until full -------------------- |
![]() Enthusiast ![]() ![]() Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) ![]() |
open fill cap drain oil remove filter install drain plug install filter install 4 quarts of oil replace fill cap start engine for 20 seconds turn off engine wait 5 minutes check dipstick add oil until full Voila -------------------- |
Enthusiast ![]() Joined Feb 18, '07 From Calgary, Alberta Currently Offline Reputation: 0 (0%) ![]() |
mine takes a tad below 4L perfectly
Lo-Fi Version | Time is now: April 24th, 2025 - 4:20 AM |
