4 Pages V  < 1 2 3 4 >
> My Celica hifi project
post Sep 2, 2008 - 3:00 PM
Rizer
Joined Aug 20, '08
From Norway
We did "rip" the vinyl off the door as you may see in the pictures.
Then we add some spattle, and this way builing up the door to a flat round surface.
This post has been edited by Rizer: Sep 2, 2008 - 3:08 PM
post Sep 6, 2008 - 2:33 PM
Rizer
Joined Aug 20, '08
From Norway
Now we are almost finished with the new floor, and the wiring.
I think we should be done next weekend.
post Sep 6, 2008 - 5:14 PM
AnaXyd
Joined Jul 15, '08
From Norway
Looks great! smile.gif You are using some of my ideas in the trunk.. smile.gif (I am from Norway too, got a big worklog on diskusjon.no)
A nice tip would be to separate the power and signal cables to prevent noise. The connection cables are good though, but it may be noise.. smile.gif
Are you planning to do some dampening in the trunk with vibroplast?
This post has been edited by AnaXyd: Sep 6, 2008 - 5:15 PM
post Sep 8, 2008 - 12:18 AM
itssteve
Joined Dec 14, '07
From yorktown Va.
hey man this looks really good, im just wondering what are the deminsions of the amp in the pics because i have an install that i wanna do but i dont know if the amp that i have is to big or not to go in there, thanks and sorry for post dumping
post Sep 9, 2008 - 5:33 AM
Rizer
Joined Aug 20, '08
From Norway
QUOTE (itssteve @ Sep 8, 2008 - 1:18 AM) *
Hello.
Just follow this link, and you will find the dimensjone at the bottom of the page.
Technical info LRx 5.1
Length:53,8 mm
post Sep 11, 2008 - 5:14 PM
itssteve
Joined Dec 14, '07
From yorktown Va.
thanks that really helps out man, i really think that im gonna have to go this route when i re-do my set up in a lil while, cause i have no place other to put this amp, keep up the good work man i cant wait to see how this turns out in the end
post Sep 13, 2008 - 5:30 AM
Rizer
Joined Aug 20, '08
From Norway
We was not happy with the rear speaker instalation, so we have now made 2 MDF adapter rings.
This way we got the speaker closer to the "door panel", and the acoustic shortcircuite is now history.
We did also added a foam ring around the speaker, just like the originale ones.
post Sep 13, 2008 - 12:33 PM
Legit94GT
Joined Feb 6, '08
From Oregon
That is basically what i had in mind when i upgrade my rears to 6x9s, but i was worried about putting the plastic piece back over it, when you used the think mdf board does the plastic piece fit right back where it should or di you have osme fitament problems?
Great build
1 JL 1,000/1v2
2 JL 12" W6v2
2 Focal 6.5 component 165a1
Kenwood DDX512 head unit
Running 142.6db with the back seat up:)
post Sep 14, 2008 - 2:51 PM
Rizer
Joined Aug 20, '08
From Norway
IT'S ALIVE AND KICKING!!!
Pics will come.
post Sep 14, 2008 - 2:55 PM
Rizer
Joined Aug 20, '08
From Norway
QUOTE (Legit94GT @ Sep 13, 2008 - 1:33 PM) *
Great build
Mine 6,5" fitted just like the origian ones, no problems at all.
I shall take some pics, and post them soon.
post Sep 25, 2008 - 12:11 PM
Rizer
Joined Aug 20, '08
From Norway
Here we have some pictures of the rearspeakers in place.
As you can see, they fit snug thanks to the MDF rings and foamsurrondings.
This is very important, as you will loos the closed box effect with out it.
post Sep 25, 2008 - 12:19 PM
Rizer
Joined Aug 20, '08
From Norway
QUOTE (Rizer @ Sep 14, 2008 - 3:51 PM) *
Pics will come.
Well there has been a little slow around updates, now that the system is up and working.
Here is a picture of the half finished installation.
This post has been edited by Rizer: Sep 25, 2008 - 12:20 PM
post Sep 25, 2008 - 4:55 PM
petna
Joined Mar 2, '08
From Manchester - UK
not convinced with how the power and speaker cable is run together to be honest. loving the rear speakers though
www.celica-club.co.uk
My Garage
post Sep 25, 2008 - 5:01 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
Nice which hertz speakers are you using as this is what I have in my setup as well.
(Headunit)
Pioneer Premier FH-P800BT Dual Din
(Front)
Hertz ESK 163L Speakers
6 1/2 inch Woofer
4 inch Mid range
3/4 inch Tweeter
92 dB/spl
250W peak 125W RMS
50Hz - 23 kHz
4 Ohm
(Rear)
Hertz DCX 165
6 1/2 inch 2 way Coaxial
93 dB/spl
120W Peak 60W RMS
60Hz - 21 kHz
4 Ohm
(Subwoofer)
2 JLW010
Running at 2 ohm Bridged
(Amp)
Alpine MRP-M450 Mono Block
and are you going to setup a 4 way for them ? or only a amp for the woofers?
post Sep 26, 2008 - 1:32 AM
Rizer
Joined Aug 20, '08
From Norway
QUOTE (petna @ Sep 25, 2008 - 5:55 PM) *
Oh.. Yes it's just temporary, we was so eager to hear what it sounds like, so everything was just "thrown in".
This post has been edited by Rizer: Sep 26, 2008 - 1:33 AM
post Sep 26, 2008 - 1:40 AM
Rizer
Joined Aug 20, '08
From Norway
QUOTE (Daftboy @ Sep 25, 2008 - 6:01 PM) *
(Headunit)
(Front)
Hertz ESK 163L Speakers.
6 1/2 inch Woofer We use Space 8
4 inch Mid range We use ESK 130
3/4 inch Tweeter We use Space 1
92 dB/spl
250W peak 125W RMS
50Hz - 23 kHz
4 Ohm
(Rear)
Hertz DCX 165
6 1/2 inch 2 way Coaxial We use EXC 165
93 dB/spl
120W Peak 60W RMS
60Hz - 21 kHz
4 Ohm
(Subwoofer)
2 JLW010 We use ES 300
Running at 2 ohm Bridged. Same as we do.
(Amp)
Alpine MRP-M450 Mono Block We use LRx 5.1
This post has been edited by Rizer: Sep 26, 2008 - 4:01 AM
post Oct 26, 2008 - 5:54 AM
Rizer
Joined Aug 20, '08
From Norway
We have now recived the new neonlights.
Pics will come soon.
post Oct 26, 2008 - 8:48 AM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
What are you talking about exactly with the closed box effect for the rears? Mine sound pretty bad and I'm trying to figure out why.
post Oct 26, 2008 - 9:28 PM
razor7
Joined Jul 9, '08
From California
QUOTE (RickJamesBish @ Oct 26, 2008 - 8:48 AM) *
Nah, just take a look at the cone, make sure they're in good condition. If you have new ones installed, then make sure that everything is tied down correctly. Follow this guy's plan and put foam in between the speaker and the adapter/holder. This will eliminate rattle. I would also recommend the 3/4 panel dampening, it'll save you a lot of hassle later.
Rizer, if you are planning on redoing the wiring to the rear, put down some sound dampening material along the whole bed of the car. It'll help out a LOT when you cruise on the freeway. Helps eliminate a vast majority of the road noise we suffer from, you'll thank me later! :-D
-TC
Live your life for yourself. Don't hold back for anything or anyone.
post Oct 27, 2008 - 10:20 AM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
QUOTE (razor7 @ Oct 26, 2008 - 10:28 PM) *
-TC
Yeah right, I would kill if I my two-month old speakers were blown! It's distortion. I think my HU isn't powerful enough to power all four. They're also sitting on the old glue from the speaker, so it's not rattle. The fronts are sealed onto the adaptors with the adapters sealed to the housing. I think I might just need an amp...
And looking at his pictures, I don't even know if I have that surround that he has. Would the foam in between the speaker and the housing really help, since it's already seated in well enough.
Lo-Fi Version Time is now: December 11th, 2024 - 8:45 PM
