> Worn control arm bushing..., Can't lower my car because of it...?
post Aug 24, 2008 - 4:06 PM
supaneko
Joined Jul 31, '08
From Lansing
I recently purchased the necessary parts to lower my car (springs, struts). With every job like this the vehicle requires an alignment and to get the alignment, the car's suspension system was checked.
I was told that I could not have an alignment performed because a control arm bushing was worn. frown.gif
I am a little frustrated because the bill for this is about $400 (parts & labor).
I was thinking of buying just the part and then taking it to a friend to perform the labor. My problem, it seems that you must purchase the entire control arm in order to replace the bushing.
Does anyone have any ideas on what I can do? Perhaps there is a better place to find the part (currently $175 from local Toyota dealer) or...?
digitalctrl
Lansing Computer Repair
Laptop Repair
Geek Squad Alternative
Don't hate me...I'm a friendly n00b. :)
post Aug 24, 2008 - 6:16 PM
supaneko
Joined Jul 31, '08
From Lansing
OK. So I found a replacement control arm, OEM, from (correct me if the name is wrong, please) 1st Toyota. Excellent price; about $100 cheaper than what the dealership wanted. biggrin.gif
digitalctrl
Laptop Repair
post Aug 25, 2008 - 11:10 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
this guy deserves 6gc rookie of the year! rookie+search button FTW! glad you found it man! toyota told me the same thing, but i remember my control arm being more than 175. its a shame the whole thing has to be replaced mad.gif
post Aug 25, 2008 - 11:49 AM
control arm is a fairly easy and quick replacement, just getting it to slide out is the fun bit
post Aug 26, 2008 - 4:25 PM
supaneko
Joined Jul 31, '08
From Lansing
Fairly easy you say? Geniuses at the shop told me that there was a spring in there that will pop off as I remove it.
Looks like I should run out and get a Chilton's and possibly save myself some money.
BTW, the site is called 1st Toyota Parts (for future reference smile.gif ).
digitalctrl
Laptop Repair
post Aug 26, 2008 - 6:45 PM
there is no spring here are pictures of the break down
L & R assemblies
disconnect your knuckle via 3 bolts/nuts
remove sway bar link
and how you do that
remove the 2 other LARGE bolts that hold it to the K frame
and you'll end up with these when you are done
Lo-Fi Version Time is now: January 10th, 2025 - 4:58 PM
