> Throttle Resonse, 4age throttle
post Aug 25, 2008 - 7:11 PM
white97
Joined Sep 1, '07
From south carolina
okay so i got the 4a in with the right throttle cable but my question is, does anyone know why theres a little bit of a delay with the throttle?
post Aug 25, 2008 - 7:38 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Sticking, IDK what it's actually called, but that round metal flappy valve thing that opens up on the TB when you accelerate. It can get pretty gunky over time and built up with carbon, which can cause it to stick. If you remove your TB and clean it thoroughly (being mindful of the plastic sensors, of course) you may notice a nice difference in throttle response.
Also, be sure your cap, rotor, plugs, wires and air filter are not worn down/dirty. These will also delay throttle response.
post Aug 25, 2008 - 9:14 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
fuel pressure problem?
post Aug 25, 2008 - 11:10 PM
white97
Joined Sep 1, '07
From south carolina
im not sure i had another post about whether i needed to upgrade the fuel pump from the stock 7afe one but the guys told me it'd be fine to run the stock one. i was thinking that might be, almost like its not getting enough pressure. it might be that i havent driven it in a while and it may just need to let the fuel thats been sitting in it run through again im really not sure.
Lo-Fi Version Time is now: December 1st, 2024 - 12:28 AM
