10 Pages V  « < 5 6 7 8 9 > »
> Guess what I did this weekend, st205 w/ e153 - pg5 335whp, vids pg7
post Feb 10, 2009 - 8:06 PM
QUOTE (jgreening @ Feb 10, 2009 - 8:00 PM) *
Truly amazing results. It has me scratching my head given the fact that after being available for 14 years, the best ct20b dyno over on mr2oc is 316whp. Do we chalk this result up to intercooling? Any possibility of a chipped ECU or modified stock turbo?
If you look over at the mr2 guys and over at our own little 3sgte scene, you'll notice that we almost always make more power then they do with the same mods. There are two reasons for this.
1. Better intercooling. We can fit huge front mounts, or topmounts that work properly, while most of those guys are stuck with tiny side mounts that cant compete with our cooling.
2. There is a difference between the mr2 and the alltrac ecu in terms of tuning. There is actually a book out about tuning that goes into detail how the mr2 ecu's get less aggressive tunes then the alltrac does.
post Feb 11, 2009 - 5:01 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
Amazing numbers... you have done unbelievable work!
post Mar 11, 2009 - 12:01 AM
QUOTE (malpaso @ Feb 11, 2009 - 5:01 AM) *
UPDATE
Water Injection
and some pics of how I installed
I used the Devil's Own water injection system with a 3gph outside mounted nozzle, mounted, tapped into the 3s throttle body
flash off
flash on
and I put the pump into the bay, on the frame rail, 2 pics
I wired the WI relay into the relay box in a relay spot that wasn't used anymore to hide and keep the wiring clean. Then mounted the 2 gallon tank in the bay, with a custom bracket.
I was also cool enough to put an LED next to my boost gauge to let me know when the WI was activated (thanks for idea Art wink.gif ).
^^ It's pretty lean at idle (15.3-16.6)
green = go faster.
next is a new muffler, more info on that in the next few weeks.
better daylight pics tomorrow of the bay and the routing.
post Mar 11, 2009 - 12:29 AM
Everybody's always ganking my ideas !
post Mar 11, 2009 - 3:47 AM
post Mar 11, 2009 - 7:53 AM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
Could you talk about the reasons for the nozzle placement. I don't know the advantages that come with placing it so close to the tb, I have mine like 7 inches from it, so I'd like to know if there is a more ideal spot.
post Mar 11, 2009 - 8:13 AM
QUOTE (jcaron9gt4 @ Mar 11, 2009 - 7:53 AM) *
its the only spot he has for it with the w2a ic.
the farther you place it from the TB the more cooling effect you get from the water.
post Mar 11, 2009 - 5:32 PM
few more pics.
post Mar 11, 2009 - 6:13 PM
Homeboy.. move that line away from that throttle cable or anything metal ASAP.
post Mar 11, 2009 - 6:20 PM
Fate
Joined Nov 30, '04
From Atlantic City
looks good dustin! btw you have PM.
post Mar 11, 2009 - 9:16 PM
QUOTE (lagos @ Mar 11, 2009 - 6:13 PM) *
already on it Art, I'm going to protect it this weekend, just need to pick something up from the garage.
QUOTE (Fate @ Mar 11, 2009 - 6:20 PM) *
sorry I haven't responded yet, I'll PM you back later tonight.
post Mar 12, 2009 - 5:36 PM
ok so I protected the WI line today.
I used a hose (actually a goodyear rubber fuel line hose - 1/4in ID) and managed to slip it over the WI line to help prevent rubbing and any sort of failure from heat.
couple of phone pics
post Mar 15, 2009 - 5:52 PM
new mod
step 2 in a couple of weeks.
post Mar 15, 2009 - 7:51 PM
lol...need vids asap of how this incredible exhaust sounds!
post Mar 17, 2009 - 9:13 AM
jcbass7
Joined Apr 20, '06
From Florida
wow Dustin I have been out of the loop for way too long your car looks great! keep it up, and maybe I'll manage to get to RI sometime soon to see it!
post Mar 22, 2009 - 6:42 PM
here's some quick no muffler vids taken today, my new magnaflow should be going in soon
just a couple drive by vids, I should have gotten on it more
and a quick gauge vid, nothing special, 15psi 2nd to third pull, and I shifted too early smile.gif
all vids taken were on a closed road.
post Mar 22, 2009 - 7:04 PM
Thats with the cutout closed right?
It actually doesn't sound as bad as i thought it would.
post Mar 22, 2009 - 7:47 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
cutout is closed.
It actually sounds pretty good, it's quieter than Manny's and Jeff's... louder than mine though smile.gif
I <3 Dustin---07/16/06
post Mar 23, 2009 - 3:29 AM
post Mar 26, 2009 - 10:03 AM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
looking great! i like the sound, but was def. expecting it to be louder
1994 Toyota Celica ST Turbo
1991 Toyota MR2
MySpace
Lo-Fi Version Time is now: November 23rd, 2024 - 8:28 AM
