> Need alignment after installing springs?
post Aug 27, 2008 - 12:51 PM
reko
Joined Apr 17, '07
From Montreal, QC, Canada
I wanna install my TRD lowering springs this weekend on my new KYB GR-2 thing is I have already installed the shocks...
Will i need to do an alignment after reinstalling the shocks?
post Aug 27, 2008 - 1:09 PM
manphibian
Joined Oct 13, '06
From UK
i would recommend it, yes. The lower springs will change all the angles. Camber will most likely be out too.
post Aug 27, 2008 - 1:54 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
YES! Although if doing larger wheels/tires at the same time, it may not be too out of whack. The largest effect is going to be seen in the Toe-In (ask how I know). Camber will be affected, but depending on wheels/tires it may or may not be extreme. Case in point: Tein S-Techs and 18x8 wheels w/225/40 tires was a perfect -1.7* on each side after settling, but it DESTROYED the stock 15" wheel/tire combo on the inside tread up front in a matter of a few weeks.
post Aug 27, 2008 - 2:26 PM
Taskbot
Joined Jun 6, '08
From Hamiltron, Ontario
QUOTE (Fastbird @ Aug 27, 2008 - 1:54 PM) *
How do you know?
(\__/)
post Aug 27, 2008 - 4:17 PM
Rusty
Joined Nov 5, '07
From New Zealand
yes but dont do it striaght away, have to let them settle in first 3-4 weeks? also the rear usually sits higher, so I'd put some dead weight in the boot like water bottles (about 3-4 20L)
post Aug 27, 2008 - 5:46 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
well i just did my alignment and they couldnt fix alot. they did fix toe in and caster. i just got the eibach alignment kit and i fixed it myself and now i have roughly .6 degree alignment.
post Aug 27, 2008 - 10:46 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
QUOTE (Taskbot @ Aug 27, 2008 - 2:26 PM) *
How do you know?
post Aug 28, 2008 - 2:29 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
yes you do...
post Aug 28, 2008 - 3:39 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Taskbot @ Aug 27, 2008 - 9:26 AM) *
How do you know?
HAHA i can scan my alignment sheet if you want tongue.gif to show how off my car was for 4 months and is still off.......camber only though tongue.gif
post Aug 28, 2008 - 10:36 AM
reko
Joined Apr 17, '07
all right i needed one anyway... ever since i install my new steering, its always half a turn on the left
post Aug 29, 2008 - 4:07 PM
Taskbot
Joined Jun 6, '08
QUOTE (808celica @ Aug 28, 2008 - 4:39 AM) *
How do you know?
Hmm it was kind of a joke (because he asked to ask him) but now you've got me intrigued. Poast pics.
(\__/)
post Aug 29, 2008 - 4:26 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
HAHAHa guess what i tried to scan it............
and my scanner bulb broke.............
EPIC FAIL!!!
before with springs on
after without alignment kit
This post has been edited by 808celica: Aug 29, 2008 - 4:43 PM
post Aug 29, 2008 - 6:34 PM
Rusty
Joined Nov 5, '07
From New Zealand
have you got one with the alignment done?
post Aug 29, 2008 - 7:14 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Rusty @ Aug 29, 2008 - 1:34 PM) *
top pic is the before alignment job scan and the bottom is the after the alignment job print out.
however i did get the eibach alignment kit and installed myself and fixed the rears good and the fronts also. im going to have them recheck it and fix anything neccessary if needed and ask for another print out to update my recon sheet kindasad.gif
post Sep 12, 2008 - 1:30 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
You need to buy a Camber Kit first. Otherwise doing a wheel alignment is useless.
Lo-Fi Version Time is now: November 29th, 2024 - 9:36 AM
