> How to adjust clutch pedal?
post Aug 28, 2008 - 3:41 PM
Por2geezcelica
Joined Aug 17, '08
From NY
Hey guys, i was wondering if anyone knew the proper way to adjust the clutch pedal on our cars? I notice that theres a lot of free play with the clutch pedal before it becomes nice and tight when i press it down. I bleed the clutch fluid thinking it may fix it, but it didnt fix the free play, but did make it tighter. I think i read somewhere that the clutch pedal can be adjusted by loosening a lock nut and twisting the push rod more towards the pedal? Is this the way to fix the free play? And how exactly do you do it? Thanks!
This post has been edited by Por2geezcelica: Aug 28, 2008 - 3:42 PM
post Aug 28, 2008 - 4:25 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
ok under the dash at the pedal box there is 2 adjustments, one is the adjustment on the pushrod that goes to the master cylinder, the other is the stop adjustment (the stop is also a sensor on some cars) what you do is undo the lock nut on the push rod, then pill the split pin off the pin that goes throuht the pushrod and the cluch pedal, then give it a few turns out, then reinstall the pin and see if thats better, if it is put the split pin back in, do up the lock nut and your done.
Make sure that the pushrod is not tight against the pedal when you reinstall, leave a tiny ammount of free play.
if you need more travel undo the stop and wind that backards (as in so it winds toward the drivers seat) lock it up, then adjust the pushrod again.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Aug 28, 2008 - 8:53 PM
Por2geezcelica
Joined Aug 17, '08
From NY
ok so i loosen the push rod lock nut, remove the pin that goes through the pedal, which will remove the assembly off the pedal, then turn the push rod? Which way am i spinning the push rod to tighten the freeplay? Do i want to spin it away from the pedal, or towards the pedal?
post Aug 28, 2008 - 10:01 PM
Cuts_the_Pilot
Joined Dec 15, '02
you want to turn it toward the pedal, so the u shaped piece comes closer to the seat.
post Aug 28, 2008 - 10:31 PM
Por2geezcelica
Joined Aug 17, '08
From NY
cant i just loosen the lock nut, and twist the shaft towards the pedal, then tighten the lock nut? do i have to remove the u shaped piece? Will the shaft not turn unless i remove the u shaped piece and actually twist that?
so in order to lessen the freeplay, im twisting the shaft towards the firewall, so theres less of the threaded part of the shaft inside the u shaped piece?
This post has been edited by Por2geezcelica: Aug 28, 2008 - 10:41 PM
post Aug 29, 2008 - 8:49 PM
Por2geezcelica
Joined Aug 17, '08
From NY
by adjusting the push rod, can you actually change the clutch engagement point? I feel that the clutch engages too soon. When i start to let the clutch out the clutch engages when the pedal is like 3 inches off the floor. Can i adjust it and make it so the clutch engages higher?
post Aug 29, 2008 - 9:31 PM
Cuts_the_Pilot
Joined Dec 15, '02
if you want the clutch to engage further from the floor the you need to do as i have sugested. On all the cars ive done clutch adjustment on you need to turn the "U" peice, chillax bro its a piece of piss job, just get your noggen under the dash with a torch and a spanner (prob 12mm from memory for the lock nut)
pair of pliers might be handy for the split pin.
post May 11, 2011 - 10:23 AM
whitie_bear
Joined Apr 5, '10
From Canada
QUOTE (Cuts_the_Pilot @ Aug 28, 2008 - 4:25 PM) *
damn, this sounds like exactly what i need to do to get my new os geiken twin plate clutch flywheel combo to start engaging off the floor
currently clutch engage point is the floor, i want it higher so ill do as mentioned and move the u piece closer to the seat (thus increasing the stroke of the pushrod)...is this correct? Thanks a million for this guys, feels like im driving a VW
post May 11, 2011 - 10:41 AM
I've done this a billion times and after playing around with different adjustments, i can tell you that the best way to do it is to use a ruler. Set the pedal height to 5 1/2 inches with a 1/2inch of free play. That will give you the best results.
post May 11, 2011 - 11:21 AM
QUOTE (Por2geezcelica @ Aug 28, 2008 - 11:31 PM) *
Dont remove the U shaped piece. You dont have to do it, and it would probably make the job more trouble than its worth. Just loosen the nut and twist the rod to set the pedal height. Then use the round sensor thing at the top of the pedal to change the free play.
post May 11, 2011 - 2:24 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
if you need exact specs of what the range of pedal should be i believe http://bgbonline.celicatech.com/6g/ has the exact specs...good site to have bookmarked btw...
Lo-Fi Version Time is now: November 24th, 2024 - 6:03 AM
