> help with removing exhaust manifold, removing exhaust manifold on 7afe
post Aug 30, 2008 - 11:57 AM
phelon18
Joined Aug 21, '07
From bristol, UK
i cant remove the lower part of the exhaust where the flexi pipe is situated. so far ive managed to shear 2 bolts, which actually helped a little, but i fear if i attempt to loosen the others it may cause more problems and i wont be able to remove the manifold.
is there any advice that anyone could give me?
post Aug 30, 2008 - 12:18 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
the bolts that connect the manifold to the part with the flex pipe?
soak them in penetrating oil and then use an impact gun to remove those.
post Aug 30, 2008 - 12:21 PM
phelon18
Joined Aug 21, '07
From bristol, UK
yeh thats them. this part in the picture
i couldn't understand why there is a torx bit on the end of the thread as well as a nut.
post Aug 30, 2008 - 1:36 PM
Bitter
Joined Mar 11, '06
because its a stud.
Lo-Fi Version Time is now: February 19th, 2025 - 10:53 PM
