![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) ![]() |
What exactly do you need as far as oil lines/etc when installing a custom turbo? I need an exact parts list of everything you need to run the oil lines...I decided to keep the Celica around and boost it. lol
Also, how about the MAP sensor. Is there an ECU pin it hooks up to? OR Does it replace an existing sensor? I'm getting the 2 Bar MAP Sensor from a 3sgte. Thanks. -------------------- 95 Toyota Celica GT
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) ![]() |
use the stock parts from the 3s for the oil return, They are self explanitory when you see them. The MAP replaces the existing one.
-Bryan- -------------------- Member of Team 5sfTe
OK, I'm getting all of the stock lines. So I don't need to buy any extra stuff for the coolant and oil lines then? The stock 3s stuff will work without any extra modification? Also, how will I know which lines are for coolant which are for oil...or are they the same?
Lo-Fi Version | Time is now: February 26th, 2025 - 3:28 PM |
