Can this sub be salvaged? |
Sep 11, 2008 - 5:06 PM |
Enthusiast Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
My friend gave me a 12" Type-R that had the rubber surround blow from the cone. Is it possible to fix this with some kind of adhesive to get it back on and working again? Here is a picture:
-Matt |
Sep 11, 2008 - 5:16 PM |
Enthusiast Joined Dec 14, '07 From yorktown Va. Currently Offline Reputation: 1 (100%) |
you could try a CA glue or something like that it sould hole if you can give it presure i would just take it easy on the sub for a lil while to make sure that it will hold good and dont give the woofer to much power those type r's really dont want more than 500 watts
Sep 11, 2008 - 5:21 PM |
you could try a CA glue or something like that it sould hole if you can give it presure i would just take it easy on the sub for a lil while to make sure that it will hold good and dont give the woofer to much power those type r's really dont want more than 500 watts What exactly is CA glue? I wanted to see if standard super glue could work first. And I won't be powering it up in my car for awhile, I just wanted to see what I could do to get it fixed. |
Sep 11, 2008 - 9:53 PM |
Enthusiast Joined Jun 3, '06 Currently Offline Reputation: 0 (0%) |
my friend had some type rs but and he blew them underpowering them and it looked alot like that. He glued them back with i think super glue and they sound about like they did before (very underpowered) but it has held for almost a year now.
Sep 11, 2008 - 9:54 PM |
CA glue is basically super glue with a special chemical in it to make it dry faster and a little stronger, it can be had at hobby stores and Krazy glue from walmart is the same thing it just takes a little longer to dry, you normally dont have to use a lot of it but it couldnt hurt to use a good bit for something like that
Sep 12, 2008 - 3:40 AM |
Enthusiast Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
def try some glue and take it easy on it at first... I have two type R's and they do like to be around 500 rms a piece.
Sep 12, 2008 - 4:30 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
Use Poli-bond. its a flexible adhesive that i used to salvage my sub
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Sep 12, 2008 - 9:23 AM |
Sep 12, 2008 - 11:22 AM |
Enthusiast Joined Jun 13, '07 From Whitby, ON, CAN Currently Offline Reputation: 6 (100%) |
it looks bad but a regular clear silicone culk if you can access from both sides will work fine.
Sep 12, 2008 - 11:25 AM |
Enthusiast Joined Dec 9, '05 From Long Beach Currently Offline Reputation: 1 (100%) |
don't use super/crazy glue if the surround is rubber!
it will eat the rubber away! i learned the hard way! -------------------- Is this good enuff 4 ya? :D
Sep 12, 2008 - 2:09 PM |
Enthusiast Joined Jun 2, '08 From Fort Worth, Texas Currently Offline Reputation: 9 (100%) |
find some ruber opoxy that should work like tire repair glue or something
Sep 12, 2008 - 2:12 PM |
There's a fabric glue you can get at Michael's or a craft place called Tacky glue - it would be perfect for this because it will retain a little bit of flex. Basically it's like Elmer's glue but WAY stronger and with that little bit of flex.
Sep 12, 2008 - 3:40 PM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
RTV anyone? Used it at work to seal an air leak on a portable air breathing unit. Thats gonna put out way more pressure than the sub.
Lo-Fi Version | Time is now: November 29th, 2024 - 11:05 AM |
