Newcomer, 3SGTE Engine Litre Question, Engine Swap |
Sep 22, 2003 - 5:55 PM |
Enthusiast Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
Hi, everyone.
I just got a 94' Celica and its pretty trashed. Everything is in pretty good condition but the paint is horrible and its got 160000 miles on it. BUT I got hookups on engines cuz I own a shop in big bear and my mechanic knows people. Well he told my Pops that he can get a 2.2 litre engine that would fit right into the Celica ST (He was just looking for the biggest application), but I wanted a 3sGTE and am not sure if the 3sGTE had a 2.2 litre engine. The 2.2 litre engine has 18000 miles on it and is gonna cost me $500 for the front clip plus performance/turbo headers and exhaust. Anyways can someone tell me if there was a 2.2 litre engine for one of the Celica GT's in Japan and if it is 3SGTE. Thanks |
Sep 22, 2003 - 7:25 PM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
the 2.2 L is the USDM 5sfe, used in USDM 6th gen celica GTs and also in USDM MK2 MR2 Non-turbos. the 3sgte and its counterpart 3sge, are both 2.0L. the 5sfe is 135 HP. and the 3sgte ranges from 185HP to 255HP (feasibly) and the 3sge ranges somewhere like 180HP to 220HP (feasably). and none are just direct drop ins for a ST celica, all of the above need new transmission and new drive axles as well as new shift cables and wiring harness, ECU, etc.. theyre all do-able just not as simple as your mechinic is making it out to be.
-------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Sep 22, 2003 - 7:27 PM |
Enthusiast Joined Oct 27, '02 From Barbados Currently Offline Reputation: 0 (0%) |
There is not 2.2l 3sgte. Can be with a stroker kit. Its your choice. If you like power and can drive and willing to spend some money, go for the 3sgte.
-------------------- West_Minist
Hydra EMS Dealer & Tuner Subaru ECUFlash Tuner http://www.socob.bb http://xtremeracingtuning.com Viciously Tuned, Driven Hard |
Enthusiast Joined Dec 21, '02 From Orlando Currently Offline Reputation: 0 (0%) |
The 2.2L engine is most likely a 5S-FE from a Celica GT model. It's a naturally aspirated engine with approximately 135hp. The 3S-GTE motor is a 2.0L Turbo with approximately 190hp-255hp depending on the motor's generation. I may be incorrect, but I think i'm atleast somewhat close. Hope this helps.
Sep 22, 2003 - 9:46 PM |
Thanks guys. I knew about the drop in, I meant it came with the tranny. Well I guess I am not getting it, probably going to get the 3SGTE
Sep 23, 2003 - 7:39 AM |
Good choice. Just check the turbo when you get the engine. Also check the condition of the engine when you get it. Helps you to prepare for problems in the future.
Lo-Fi Version | Time is now: December 4th, 2024 - 2:50 AM |
