check engine light code 31!!!??? |
Sep 13, 2008 - 4:55 PM |
Enthusiast Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
ok my 94 st celica is running like crap spits and sputters, almost like it is out of time. it also is giving me a code 31 . i know it is the vaccuum sensor (map) so i got a new one and put it in , still is giving me a code 31, do you all think it might be a ecm problem . i did not have any trouble with it untill i washed the motor , ran good all the way home ,but as soon as i turned into the drive way , i had a (cel) and it started to run very ruff. any ideas
Sep 13, 2008 - 8:36 PM |
you probably got water into the connector, spray it out with starting fluid and make sure the vacuum line is well connected.
Sep 14, 2008 - 1:44 PM |
you probably got water into the connector, spray it out with starting fluid and make sure the vacuum line is well connected. ok i tried that and still has a 31 code, also i should also let you all know that it has set in the garage for about 7 month now since i have had this problem as i dont want to hurt any thing and it is not my DD . -------------------- |
Sep 14, 2008 - 2:54 PM |
i think its dried out after 7 months :lol: so i doubt water is the problem anymore.
try replacing the sensor and the vacuum line that connects it to the engine. -------------------- |
Lo-Fi Version | Time is now: January 11th, 2025 - 7:49 PM |
