Grindng Noise - PLEASE HELP, Grinding noise from Left front corner |
Sep 15, 2008 - 7:10 AM |
Enthusiast Joined May 24, '05 From Malta Currently Offline Reputation: 0 (0%) |
Hi Guys,
I have a strange noise coming from the left front corner. It happens when mostly when I turn to the right, but also when I go straight and go over a speed bump for example. The most interesting thing is that when I turn and release the clutch (putting the engine under load) the noise goes away. When I turn with the clutch engaged or no gear (no load) the sound is there again. First I thought it was a CV, or bearing or the usual stuff so I jacked up the car. With the front wheels off and the ebrake on I put it in revense and release the clutch slightly to put it under load and there is the noise again. It sonds like its coming from the gearbox, or dirve shaft area. I replaced a cv boot lately and had to take out the drive shaft. I had put it back in without replacing the spring washer that is on the drive shaft end in the gearbox. Could this be the cause of everything? Do you know if there should be some shaft play in and out of the gearbox? nothing major just a couple of millimeters. PLEASE HELP GUYS. Thanks |
Sep 15, 2008 - 2:40 PM |
bump anyone?
Would it be a safe bet to start by replacing the rear engine mounting? |
Sep 17, 2008 - 7:15 AM |
Enthusiast Joined Sep 8, '08 From Ireland Currently Offline Reputation: 0 (0%) |
By what your saying it sounds like the ball joint in the gear box having it in gear should stop the noise but when it is out of gear it is free to float about. Might be that. Hope this helps
Sep 22, 2008 - 10:45 AM |
Is ther a ball joint in the gearbox?
Sep 22, 2008 - 5:41 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
maybe your low on gear oil????
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Lo-Fi Version | Time is now: November 29th, 2024 - 6:59 PM |
