Oil Pressure Sensor Plug, Where can I pick up one of these? |
Sep 17, 2008 - 8:55 PM |
Enthusiast Joined Sep 15, '08 Currently Offline Reputation: 0 (0%) |
So, today I was messing around under my hood and noticed that the wire running to my oil pressure sensor plug was disconnected. I took the plug off the sensor and checked it out to see if the wire can be re-attached. Doesn't look like it. Anyone ever had to buy one of these? No one seems to carry the plug itself. I think Autozone and other places need to start carrying these things 'cuz as our cars get older, that plastic gets brittle.
Sep 17, 2008 - 9:02 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
If you notice theres a tiny hole on the end of the prong coming out of the knock sensor itself. Just strip the sensor wire and needle it through the holand tape it. You'll be set.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Sep 18, 2008 - 11:17 AM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
or you can simply go to a salvage yard and pull that plug with about 6 inches of wire and pocket it. then you just splice it right in.
-------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Sep 18, 2008 - 2:19 PM |
I'll try #1 and then #2 if to no avail. It's pretty brittle.
Thanks, guys. |
Sep 18, 2008 - 3:12 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
I've got them here too, if #2 fails.
And don't try #1, my .02. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 18, 2008 - 8:35 PM |
I used a Dremel Tool to take out the left over wire in the plug itself and re-threaded it. Clipped it back on and it works like a charm. I'd like to replace it with a few other aging plugs but it's a good fix for now.
Lo-Fi Version | Time is now: November 30th, 2024 - 7:12 PM |
