Insufficient EGR Flow...?, who wants to help me out? |
Sep 18, 2008 - 11:25 AM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
ok so i threw a CEL and I came up with a "Insufficient EGR Flow"
I'm going to start working on it now, but if anyone has some insight I would love to hear it! -------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Sep 18, 2008 - 12:24 PM |
replace it or attempt to clean it with cleaner.
Sep 18, 2008 - 10:47 PM |
yeah i figured... just wantd someone elses .02
Sep 18, 2008 - 10:49 PM |
Sep 18, 2008 - 10:50 PM |
Nate, pull off the EGR, clean it and clean the filter in it (on top) and take off the metal tube that goes from the EGR to the head, clean it out good and try to clean out the hole where the tube goes into the head.
Sep 18, 2008 - 11:50 PM |
Enthusiast Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
how difficult is it to take off the EGR? just a couple fittings?
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Sep 19, 2008 - 8:30 AM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
on a 5sfe, it's a pain in the hassle. lol. It's whats kept me for doing mine for a while. (i've got an infant though, so i've got limited working time) The big tube that Batman was talking about, is like a 24 or 26MM and it's a pain to get to. You have to go between the head and the throttle body/air intake area. The line cannot be taken off directly by the EGR (atleast it isn't possible for me )
Clean that filter first though!! I cleaned mine and that was that. (i'll come on for a few miles about every 2 weeks or so) but i've got to goto the toyo dealer when it opens back up (recent hurricane devistated my local toyo place) and buy a new one. Also, check all your hoses to see that nothing is clogged up. Try that first, then if it fails, go ahead and clean it out. EGR's dont really go "bad" I'd replace all the hoses & filters before buying a new one. Hope it helps. G/L. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Sep 19, 2008 - 9:57 AM |
Enthusiast Joined Dec 24, '06 From jonesville Currently Offline Reputation: 4 (100%) |
i had the same problem...only mine was in the intake manifold..where the egr bolts to the manifold theres a hole...mine was clogged.
Sep 19, 2008 - 10:50 AM |
i have the same code, i havent had a chance to fix it yet orinvestigate whats clogged.
Sep 19, 2008 - 11:28 AM |
Enthusiast Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) |
It's not that hard to get off, as long as you have tools that can fit in the small working area. 2 nuts that hold the EGR in place and then unscrew the metal pipe where it connects to the manifold, not where it connects to the EGR. Card cleaner the crap out of it, give it a good scrub. (I'm going to have to look for this filter. I never knew there was one when I cleaned mine. is it hard to get off?)
Sep 19, 2008 - 12:06 PM |
not difficult at all. Just a little bit harder than removing the vac lines
It's the UFO shaped cylinder next door (to the left) of the EGR itself. Pop off the black top, and there it is... *Sparkle* *Sparkle* lol, it probably wont sparkle though , You can wash it with water and a dry towel. make sure it's dry before you put it back in. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Sep 19, 2008 - 12:34 PM |
Cool. I'll have to give that a shot. When I cleaned just the egr, pipe, etc, it lasted for quite a while without throwing codes, but it eventually came back like a year later.
Sep 19, 2008 - 1:54 PM |
that's probably your filter making that code then. or one of the smaller vac lines having gyunk in it.
Clean the filter and check the rubber hoses first, then go thru the trouble of pulling and cleaning the main-vain... Then if that fails, Replace. Sometimes the simplest (and cheapest ) solution is the best Although sometimes not But trouble shoot from easiest to hardest. Saves the most money. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Sep 19, 2008 - 2:10 PM |
its the 0401 code right? or sumthin like that
Sep 19, 2008 - 2:18 PM |
I dont remember... it was awhile ago... And NgoFcukway ran and counted the code, And DEATH looked it up for me. I was busy messing with something else. (sometimes we have Car-Fix Parties; Like a party, but instead of dancing; We repair cars. We still drink though )
Sep 22, 2008 - 1:01 PM |
not difficult at all. Just a little bit harder than removing the vac lines It's the UFO shaped cylinder next door (to the left) of the EGR itself. Pop off the black top, and there it is... *Sparkle* *Sparkle* lol, it probably wont sparkle though , You can wash it with water and a dry towel. make sure it's dry before you put it back in. I tried popping off the top but couldn't do it. do i twist the top or wat? -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Sep 22, 2008 - 1:05 PM |
no. It pops. Like a milk cap.
If you're standing facing the car, It's too the left of the EGR. Use your fingernail or a flathead screwdriver if you must. IIRC you gotta put a little bit of force into it. Dont break it though, it's only plastic. lol. But it dosen't come off easy, its not made to be changed often... if ever... -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Lo-Fi Version | Time is now: November 30th, 2024 - 10:15 AM |
