> Bulb Adapter for Projectors
post Sep 19, 2008 - 12:25 AM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
Is there a bulb adapter that goes from a 9006 bulb to a H1 bulb? I don't want to cut any wires for my projectors. Couldn't find any info from google or 6gc. The only thing I heard of is a guy making one from another car forum, i suppose i can do that but i dont have time right now. Thanks in advance ! smile.gif biggrin.gif
This post has been edited by CaliJeff: Sep 19, 2008 - 12:30 PM
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Sep 19, 2008 - 12:29 PM
CaliJeff
Joined Apr 22, '07
Anyway, did some more research. So a 9006 bulb in the lighting world is also called a "HB4" bulb. So i need to go from a HB4 male to a H1 female. H4 bulbs also work, there is just an extra prong. Found a website which does such a thing for $45 a pairHere
Here is what they look like http://www.suvlights.com/popup_image.php?pID=232&image=0
There is also a difference in H1 bulbs. There are the Euro type and JDM type when looking for aftermarket parts. So be careful. At the dealership, they want bout $14 for each connector for the projectors (ouch), thats without wiring too.
So if you want to make your own, you can just get the connectors and some wire and solder everything together, Here is where you can get such material for $5 each. Remember though you need 2 connectors of each, so 4 in all, (unless your projectors came with the harness, and i'm already looking at $20 for the connectors themselves.
post Sep 19, 2008 - 12:55 PM
ComaDave
Joined Jul 16, '03
From Sandy, UT
Make sure you don't cut your existing headlight plugs. The picture you linked looks like the plugs I used (parts from a honda of some sort), then I wired them to a spade connector that I wired to the existing headlight plug. I used a bunch of electrical tape in the process, but haven't had any issues in the 4 or so years I've had them. If it isn't stickied, I'm sure there was a thread with the correct honda part number way back when.
This post has been edited by ComaDave: Sep 19, 2008 - 12:57 PM
post Sep 19, 2008 - 2:43 PM
frisp
Joined Jan 2, '08
From Scotland
I made a small adaptor loom.For each side I used 2 female crimps, 2 pin type crimps, some black & red wire.. Been in 1 year now, no problem tongue.gif
Regards
frisp
HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier
Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's
JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6
To be done....
Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads
post Sep 19, 2008 - 2:44 PM
CaliJeff
Joined Apr 22, '07
whats a crimp and whats a loom
post Sep 19, 2008 - 2:50 PM
frisp
Joined Jan 2, '08
From Scotland
A loom is just a bunch of wires, in this case 2 bits per side. I used proper crimps for the connectors like these
And for the connectors
Regards
frisp
To be done....
post Sep 19, 2008 - 6:57 PM
CaliJeff
Joined Apr 22, '07
post Sep 19, 2008 - 7:24 PM
azian_advanced
Joined Apr 18, '05
From Calgary
why not just buy the h4 harness and crimp a couple of 'pins' (not sure what the proper name is) at the end of the harness and just plug 'em in to your existing 9006 connectors..
QUOTE (jason @ May 22, 2008 - 7:11 PM) *
highs are the same bulbs as your old ones so no changes there
for the lows, its pretty simple.
go to an auto parts store and buy an H4 harness, will have 3 connections arranged in a U shape and 3 pig tailes coming out the other end.
the harness plugs right onto the h1 bulbs, and i just tinned the ends of the pigtails and inserted them into the car's harness.
better details:
QUOTE (jason @ Mar 29, 2007 - 5:44 PM) *
i just got h4 connectors, pulled the one wire out of it so it was just the 2 that i need so it looks all clean, then the other end of the pig tails i just stripped them and tinned? them (made stiff w/ solder) then just inserted into the existing 9006 harness - this way no cutting and going back to stock is still possible, plus it looks clean =) just get diff diameters of heat shrink and make it all weather proof then, im working on that now actually
took 3rd wire out
simple connection no cutting
Lo-Fi Version Time is now: February 13th, 2025 - 2:57 PM
