Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 21, '08 From Naples, FL Currently Offline Reputation: 0 (0%) ![]() |
It's been like this for a while now, not sure if it's normal wear and tear.
I only have 68,6xx miles on it, and it was fine for a while until this problem came up several weeks ago. Basically, when the engine's cold, it revs up to 2k initially when I start it, then backs down to about 1k when it usually should idle at around 700 RPM. If the engine's still warm, it'll initially rev up to what it usually did, around 1.5k. It also variably idles between 500 and 1k RPM when I'm stopped. Causes? Solutions? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) ![]() |
It happened to me and it was a vacuum leak. I got a cracked hole on the little tube from the intake manifold to the engine.
But it could prolly be other things too...... -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
It's been like this for a while now, not sure if it's normal wear and tear. I only have 68,6xx miles on it, and it was fine for a while until this problem came up several weeks ago. Basically, when the engine's cold, it revs up to 2k initially when I start it, then backs down to about 1k when it usually should idle at around 700 RPM. If the engine's still warm, it'll initially rev up to what it usually did, around 1.5k. It also variably idles between 500 and 1k RPM when I'm stopped. Causes? Solutions? -thats normal cuz its warming up ![]() -clean that air sensor thingy????? -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
![]() Enthusiast ![]() ![]() ![]() Joined Aug 21, '07 From Toronto Currently Offline Reputation: 1 (100%) ![]() |
2k at start up is not normal even if it is still warming up, my car revs at 1k to 1200 at startup... try using seafoam.
-------------------- -Derick
![]() "In hoc signo vinces." In this sign thou shalt conquer." Gone but never forgotten.... |
I was gonna say, it's wasn't doing it before, so it's definitely not normal.
Seafoam to clean engine out? Vacuum leak? Air sensor? |
Lo-Fi Version | Time is now: April 23rd, 2025 - 6:52 PM |
