> need help with the right side axle
post Sep 22, 2008 - 8:48 PM
GoToSleep
Joined Feb 19, '08
From Elk Grove/South Sac
hey 6gc members i been searching the site all day about how to replace the right side axle and i could not find the info i needed so if someone could help me out it would be a blessing thank you for your time
Jayson
post Sep 22, 2008 - 9:16 PM
replacing the driver's axle.
drain tranny (24mm)
remove axle nut (30mm) and wheel
remove ball joint on the bottom of the A arm (17mm, 2 nuts, one bolt)
swing hub out of way and pry/pop axle out of tranny
post Sep 22, 2008 - 9:27 PM
Remy
Joined Jan 25, '06
From MN
The right side is the passenger side its been covered many times on this board.
"To Protect And To Serve The Wealthy" -POLICE
post Sep 22, 2008 - 9:30 PM
oh snap, pass side, by b.
do the same as driver's side but also remove bearing carrier (2 14mm bolts)
post Sep 22, 2008 - 9:42 PM
GoToSleep
Joined Feb 19, '08
do you remove the carrier axle with the main axle or leave it in the tranny if possible? and do i need to drain the tranny also or not???
thanks for your help 6gc
Jayson
post Sep 22, 2008 - 9:51 PM
the bearing is attached a bracket and that bracket bolts to another. Just remove the 2 bolts and it seperates and slide axle out of tranny.
you can drin the tranny or have it drain when you pull the axle out.
post Sep 22, 2008 - 10:01 PM
GoToSleep
Joined Feb 19, '08
just to clear things up for me no matter what i have to drain the tranny right
jayson
post Sep 22, 2008 - 10:06 PM
Remy
Joined Jan 25, '06
From MN
QUOTE (GoToSleep @ Sep 22, 2008 - 10:01 PM) *
jayson
Yes no matter what because once you get the axle out (its connected to the tranny) fluid would spill out its better to drain it oh and don't forget to get a new axle seal you will also need to get the carrier bracket pressed off and put onto the new axle.
post Sep 22, 2008 - 10:20 PM
QUOTE (Remy @ Sep 22, 2008 - 11:06 PM) *
no you don't. The bearing is sealed in a bracket, you remove one the 2 bolts and bearing/bracket assembly unbolts from a seperate bracket, it's easy.
post Sep 22, 2008 - 10:32 PM
Remy
Joined Jan 25, '06
From MN
You will need to get the carrier axle mount pressed off but take if off from the bearing bracket first.
Lo-Fi Version Time is now: November 26th, 2024 - 12:40 AM
