![]() Enthusiast ![]() Joined Sep 14, '05 From London Baby Currently Offline Reputation: 0 (0%) ![]() |
Does anybody here know whether the alternators from the Lexus Models RX300 or GS400 would fit my Gen 6 Celica. I need a larger one as im still struggling with voltage drop from my sound system. Trying to get a similar bolt pattern so i can litterally swap them over, or is it not that easy??
Ideally looking for a 120amp alt, this wouldnt put starin on the engine as its almost double the standard 70 amp one installed currently?? Cheers for any advice ![]() -------------------- Source Unit: Panasonic CQ-TX5500W (Tubular)
Amplification: Genesis Dual Mono x5, Monoblock x1 Processing: Phoenix Gold DD10, Epicentre, UCS Pro, Brax Multicontrollers Speakers: MB Quart QSD, Kenwood Cables: KnuKonceptz, Phoenix Gold Fabrication: Homebase Wood, Dynamat, Old Foam |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) ![]() |
Capacitor. It's FTMFW.
![]() -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Lol, got the t-shirt and a 5 farad one of those! Next suggestion please
![]() Little more info as to current setup Source Unit: Panasonic CQ-TX5500W (Tubular) Amplification: Genesis Dual Mono x5, Monoblock x1 Processing: Phoenix Gold DD10, Audiocontrol Epicentre, UCS Pro, Brax Multicontrollers Speakers: MB Quart QSD 3-way active, Kenwood Super-Woofer Cables: Zero gauge KnuKonceptz linked to Audison Fused distro the 4 gauge Phoenix Gold cable to amps Battery: Yellow Top in the front, looking at getting a second shortly Fabrication: Homebase Wood, Dynamat, Old Foam -------------------- Source Unit: Panasonic CQ-TX5500W (Tubular)
![]() Enthusiast ![]() ![]() ![]() Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) ![]() |
All words. We require pictures!
dude, dont get a second battery. That'll make things worse. When you've got two, then the load doubles; making the alternator have to send the power in 2 directions, it's essentially filling 2 leaking cups. Once you start your car, you battery only recharges and sits there untill you bar all the power of the alt. Not untill then will it dip into the batt, and that's usualy bad for the battary. The battary isn't intended to supply power moving that fast, thats why caps are used.
I know that GRIFFGIRL had a high load alternator for the 6th gen celicas. It was a 170V (IIRC). It needed to be re-wound. You can always take you existing alt to a specialty/machine shop and see if they can do it. But what ever you're doing to drain your stock alt, Batt, and a 5F cap, is something i'd imagine is being done wrong. I hope all of your stuff is fused. This post has been edited by D-Man: Sep 24, 2008 - 4:27 PM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Yeah, listening to it too loud for too long
![]() Are you running comps with this setup? Don't you just burp the bass for a second? Or are you using this car as a portable boombox? -------------------- ![]() |
I thought that a second battery would help as then i would have double the storage and would take a lot longer before it got down to dangerouse voltage levels? I wudnt have thought the second battery would put more strain on the alt as its only got a maximum output, and if im already exceeding that wont it jus kill my other battery?? Also arnt caps worse as they discharge too quickly and then need to steals power from the battery to recharge itself. Whats the general increase from getting your alt rewound?
This is all jus my ideas so please correct me if im wrong, jus thought id ask for second, third and forth opinions on these things ps. Pics uploaded to my profile page -------------------- Source Unit: Panasonic CQ-TX5500W (Tubular)
Yeah, listening to it too loud for too long ![]() Are you running comps with this setup? Don't you just burp the bass for a second? Or are you using this car as a portable boombox? Running 3 way active setup in the front and some 6.5" bass speakers in the rear and then a 12" sub in the boot. I only get the voltage drop when i crank the bass controller up, some times i jus get the urge to vibrate myself into submission, thats when the volts get low 11's whilst the cars on albeit at idle. I been told that if you get into the 10's on voltage thats when amps go poof!! and how u get an avatar? -------------------- Source Unit: Panasonic CQ-TX5500W (Tubular)
When my voltage went that low with my 2 15's, my stereo went into protection and shut off. If your stuff goes "poof" i'd think about getting better quality stuff. I'm surprised you get voltage drop with only that. How much power do those amps put out?
This post has been edited by Sinyk: Sep 24, 2008 - 4:52 PM -------------------- ![]() |
When my voltage went that low with my 2 15's, my stereo went into protection and shut off. If your stuff goes "poof" i'd think about getting better quality stuff. I'm surprised you get voltage drop with only that. How much power do those amps put out? lol, didnt think 6 amps was too bad ![]() http://www.genesiscaraudio.net/main/ -------------------- Source Unit: Panasonic CQ-TX5500W (Tubular)
I thought that a second battery would help as then i would have double the storage and would take a lot longer before it got down to dangerouse voltage levels? I wudnt have thought the second battery would put more strain on the alt as its only got a maximum output, and if im already exceeding that wont it jus kill my other battery?? Also arnt caps worse as they discharge too quickly and then need to steals power from the battery to recharge itself. Whats the general increase from getting your alt rewound? Okay,........ No.The battary starts the car and then goes dormant, as the altinator forces power into the chassis and positive wire stream. If you have a V meeter, you'll notice 12V togo 13-15 after you start the car. Now, Lets say that your alt is putting out 75, when your draw is 80. That extra 5 will come from the battary. Like an overdraft. ![]() Now, as for 2 battaries, If you're draining your alt's power and dipping into the batt supply; then durring it's charge phase (when your electronic crap quit's stealing the power, lol) the altinator has to put 2 equil forces into each battary. Therefore it's like trying to fill 2 leeky cups with one waterbottle, AT THE SAME TIME!!! you have to poor equil amounts in, and that amount will (attemptably) be the same as the one battarys amount. Get it? Capacitors charge and discharge quickly, this is true. But this is why they are GOOD for your car. Your amplifier is just a bunch of capicotors sitting in a box, obsorbing the audio signal and releasing it with the stored force. That's it. now, when your amp pulls most/ all the power from your alt, then it dips into your battary, and then sh!t dimms (just for a second) then the "BUMP" is over and the amp pulls a charge from the battary again, and the alt recarges the whole car for it to do it again. A capicitor, is intended to go between the amp and the battary and release this power as quick as the amp will rip it; but draws it's source slower than the amp as to not damage the battary. Unless you got a crapy cap. Mine has protection. This post has been edited by D-Man: Sep 24, 2008 - 5:07 PM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
KK makes sense to me, but i know loads of friends that get extra batteries before they upgrade alternator, so pressumed there would be a reason for this, maybe this is a quick fix solution.
If the cap "draws it's source slower than the amp as to not damage the battary", would the cap not be useless after its spent its load (for a second anyway), and the amps would then still be draining from the battery?? i got an alumpro 5farad, think thats wot its called, dont think they suppose to be rubbish, but not sure whether they got any built in protection. And i am fused to the max so no worries there. In answer to my original question you would say its wise to upgrade the alt, then if im still dropping voltage, add another battery?? Any ideas on Lexus fittings?? Appreciate the help guys -------------------- Source Unit: Panasonic CQ-TX5500W (Tubular)
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
i'm interested too..
I have a Stock Altintaor Audiobahn 1600watt amp .5 Farad Capacitor.. (had a 4 Farad but that still didn't keep from low voltage, plus stayed on and drained battery.. LOL) -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
KK makes sense to me, but i know loads of friends that get extra batteries before they upgrade alternator, so pressumed there would be a reason for this, maybe this is a quick fix solution. If the cap "draws it's source slower than the amp as to not damage the battary", would the cap not be useless after its spent its load (for a second anyway), and the amps would then still be draining from the battery?? i got an alumpro 5farad, think thats wot its called, dont think they suppose to be rubbish, but not sure whether they got any built in protection. And i am fused to the max so no worries there. In answer to my original question you would say its wise to upgrade the alt, then if im still dropping voltage, add another battery?? Any ideas on Lexus fittings?? Appreciate the help guys Yes. It would be useless; much like a second battary. That's what caps are for. You've just got some kind of insane load... I'm kinda worried about where all this power is going... But, W/e. Personaly, i do not know if a lex alt will fit you. I know the Auto's alts are 5v more than the manuel, but that's for the auto's computer. I'd take the alt to a junk-yard and compare with the lex alts. If it were me (and what i've done in the past for sound-wagons) is to take it to a specialty shop and have it re-wond and made "bigger". Goto a local customs place and ask where you could get that done at. that way they can reccomend you a local machine shop that offers that service, or can do it for you. IDK where you could get that done in "London Baby" but i know where to go in Houston ![]() ![]() -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
![]() Enthusiast ![]() ![]() ![]() Joined Sep 17, '05 From Newcastle / UK Currently Offline Reputation: 4 (100%) ![]() |
A second battery being charged through a proper split charge relay (diodes fitted to stop drawing on the vehicle battery and only allowing the audio system battery to be punished) will be a hell of a lot easier and cheaper than a high output alternator (in the UK anyway
![]() -------------------- 1994 JDM GT4 WRC
so is it a UK opinion that a second battery would help my cause. I have got a split charge relay sitting here already, but havnt got a second battery yet, so its not installed. But with the views already pointed out by others in this post this wont help, it'll jus mean my alts still stressed for longer as its got too batteries to charge??
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) ![]() |
Nope - what he said is true - if you have that relay it will help tremendously - unfortuantely at the expense of your alternator. It's having to do twice the work [or somewhere close to it anyway] so it will last half as long theoretically.
-------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Decided! a second battery is gonna be installed on the weekend. And as famous bloke from rocky once said "If he dies, he dies!" (think it was rocky)
Cheers all -------------------- Source Unit: Panasonic CQ-TX5500W (Tubular)
If you must, then DO IT WITH A SPLIT CHARGING SYSTEM!! If you just pllug them into each other, (as i mentioned before) it'll run fine for the first few min and begin doing the same.
G/L -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
That's what he and the other guy are saying. that's why I agreed with you until I found out he has that relay and intends to use it. In this case you were both right. It's the alt that will suffer from that setup.
Lo-Fi Version | Time is now: April 23rd, 2025 - 1:31 AM |
