> RPM signal from engine bay, Where to hook on?
post Sep 24, 2008 - 9:43 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Mike W
269awhp / 273ft-lbs
post Sep 24, 2008 - 11:59 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
to the coil mate, the - wire. I would assume its black as its a negative.
This post has been edited by Cuts_the_Pilot: Sep 25, 2008 - 12:03 AM
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Sep 25, 2008 - 12:26 AM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE (Batman722 @ Sep 10, 2006 - 6:46 PM) *
http://www.6gc.net/forums/index.php?showtopic=31439
QUOTE (defgeph @ Oct 8, 2005 - 11:57 PM) *
OK here goes.
I hooked mine up to a 3sgteRC.
not sure if the wire colors are the same for 5s and 3s....
Not sure if the 7a and 5s are the same.
The unit has three wires. Black, Red, Green(in mycase)
Black goes to ground. The red goes to positve, like the cig lighter.
Green or signal wire connects to the solid black wire on your ignitor in the engine bay.
DEF
post Sep 25, 2008 - 1:46 AM
delusionz
Joined Feb 11, '08
In my 2nd picture, The thick black wire with the red cap goes to the distributor, that one??? and how would you splice into that??? its meant to be EMF shielded???
Or does it mean the black wire in the middle of that black connector with 5 wires on it on the right?
Mike W
269awhp / 273ft-lbs
post Sep 25, 2008 - 2:56 AM
azian_advanced
Joined Apr 18, '05
From Calgary
i would assume it's on the big connector on the right as it leads back inside the cabin to the ECU or tachometer.. it definitely isn't the one that's on the left that goes to the distributor.
post Sep 25, 2008 - 11:35 PM
delusionz
Joined Feb 11, '08
Ah ha! If you cant find the ignition negative for RPM signal or don't want to splice into it you can find one handy in the diagnostics case labeled IGN-
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: February 18th, 2025 - 8:16 PM
