> swap question??
post Sep 25, 2008 - 8:56 AM
CeLiCa_ST
Joined Jan 14, '08
From UAE
hi
I have some questions about swaping my engine.
I have st202 with the 3s-ge and I want to swap it with the 3sge beams (Red Top), so can I use 3s-ge gear with the beams ???
because I found half kit for celica SSIII with 3s-ge beams (Red Top) but its auto trans.
and do I have to do any wiring changes to start the car???
PLZ I need help
post Sep 25, 2008 - 9:02 AM
DEATH
Joined Dec 19, '07
From tx
I have never swapped a BEAMS motor but I can tell you that you will be able to use your transmission but you will not receive the benefit of the LSD differential that comes with the BEAMS that way [Not sure if the Auto has LSD as I have 0 experience with automatics].
I would suspect there will be wiring issues - defenitly make sure you get the ECU and the wiring harness.
Hope this helps - others should be along soon to provide more expert help.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Sep 25, 2008 - 4:42 PM
CeLiCa_ST
Joined Jan 14, '08
From UAE
hi
thanx bro, I'm thinking to buy the engine complete with every thing (wiring,computer,sensors) but without the computer.
I just want to make sure that I'm not going to have any problem with the gear and the wiring.
so is there anyone who can give me more info on this swap...
thanx in advance.....
post Sep 25, 2008 - 6:36 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Dr. Tweak would know the answer to this I bet...
my initial guess would be that the ECUs are different, but I really have absolutely no idea, since it's still a 3sge to a 3sge swap. The ECU isn't available from the donor car, I take it? Why not search eBay for a BEAMS ECU? I can't imagine it'd be that hard to find actually.
post Sep 25, 2008 - 7:10 PM
QUOTE (CeLiCa_ST @ Sep 25, 2008 - 5:42 PM) *
hi
where are you located? U.S. , or united arab emirates. are you talking about the beams on ebay?
if you get an auto, your in bad shape. cuz you will need to source a manual ecu, the auto ecu is not going to work, unless you get some kind of stand alone engine managment IDK, and you will need the tach, or a tach adapter.
wiring should not be that diff, but Tweak charges around 400 for the job. Look under phoenixtuning in ebay,
or pm him.
post Sep 25, 2008 - 8:04 PM
CeLiCa_ST
Joined Jan 14, '08
From UAE
hi..
thanx guys for help...
yes, i am from united arab emirates
and I found the engine in a junk yard but its a full half kit (engine,wiring, ECU,ect...)
how much is the manual ECU and what are the changes in wiring I have to do???
post Sep 26, 2008 - 9:14 PM
wiring wise, ask tweak.
are there other goodies in that car in the junk yard, like mirror relay, splitters, etc, etc.
post Sep 26, 2008 - 11:06 PM
QUOTE (CeLiCa_ST @ Sep 25, 2008 - 9:04 PM) *
hi..
not much as for wiring IMO. If you can find a manual ECU that would be good.
post Sep 27, 2008 - 4:34 AM
CeLiCa_ST
Joined Jan 14, '08
From UAE
hi..
anyone can find for me a manual ECU or where can i find this ECU??
PLZ..
post Sep 27, 2008 - 9:26 PM
they are rare, that is why your best bet is an manual tranny engine.
http://cgi.ebay.com/ebaymotors/JDM-94-97-S...emZ250293679400
3sger from mr2, donk know if compatible tough.
post Oct 7, 2008 - 1:52 PM
CeLiCa_ST
Joined Jan 14, '08
From UAE
thanx bro
i sawp my engine and it is work
i use manal trans with auto ECU and it is work
al the guys told that i cant swap this engine if i dont have manual ECU
so can anyone give me info about the problems that i will get it in future if i use this ECU?
i need help?
Lo-Fi Version Time is now: November 27th, 2024 - 7:01 PM
