3s throttle cable |
3s throttle cable |
Sep 27, 2008 - 10:29 AM |
Enthusiast Joined Nov 28, '05 From Connecticut Currently Offline Reputation: 0 (0%) |
My 3s motor is finally set in and I'm working on getting the harness plugged in and the ic set up, but just a little problem. I had a 7afe in there before and I have the old throttle cable, but the cable is too short. Just wanted to know if anyone could tell me what cable I need, wether I could use a gt cable or maybe a 90-93 usdm 3s cable or do I need to special order a st205 cable?
Sep 27, 2008 - 3:43 PM |
You can use a 5sfe cable, but it will require modification because its actually a bit too long. When I was using it I put spacers in on the gas pedal side.
Sep 28, 2008 - 2:20 AM |
You can use a 5sfe cable, but it will require modification because its actually a bit too long. When I was using it I put spacers in on the gas pedal side. I used a 5s cable with no od at all. -------------------- |
Lo-Fi Version | Time is now: November 30th, 2024 - 12:49 AM |
