> car died while driving
post Sep 28, 2008 - 9:06 PM
foutong
Joined Feb 6, '08
From portland or
ok so i was going to my buddies house and the car died while in motion. pulled out the spark plug tester and i'm getting no spark. i'm curious how do you check if the timing belt snapped? also how would i know if it was my dizzy?
post Sep 30, 2008 - 1:54 AM
relyks95gt
Joined Sep 29, '08
From miami
same problem here but i start it back up in 10 min and it runs like normal but then if i run it for to long agian it dies out agian.. 95' gt? coincidence or it happends to most?
-RELYKS
post Sep 30, 2008 - 4:33 PM
mikew04
Joined Feb 19, '04
From austin tx
Pull off the dizzy cap and have someone crank the motor. If the t-belt is intact you should see the rotor spin.
This post has been edited by mikew04: Sep 30, 2008 - 4:34 PM
post Oct 1, 2008 - 6:09 PM
foutong
Joined Feb 6, '08
From portland or
ok the rotor is not spinning... so its safe to say that its my timing belt right? i've never done a timing belt before but i found a guide online for the 5s. how long would it take to replace it normally?
its for a mr2 but since it is the same engine i'd figure it would be the same.
i'm going to take a crack at it this weekend. anyone got any tips for me?
http://www.baktasht.com/_html/hosted/timingbelt.html
post Oct 1, 2008 - 9:03 PM
TRD_Ian
Joined Aug 19, '08
From New Brunswick
umm....if ur belt goes doesnt that mean ur valves are gonna be bent/cooked?
i hate snow, missing my celica
post Oct 1, 2008 - 9:35 PM
foutong
Joined Feb 6, '08
From portland or
i do believe its a non interference engine
post Oct 1, 2008 - 10:19 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
If the belt snapped, you won't have to worry because the 5S is a non-interference motor (thank God Toyota did that).
-Matt
post Oct 1, 2008 - 10:24 PM
97celiman
Joined May 22, '08
From dallas texas
^^^what does non-interference mean?
yayayayayayay i quoted something i am so freakin happy right now(its a long story)
post Oct 1, 2008 - 10:30 PM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE (97celiman @ Oct 2, 2008 - 12:24 AM) *
It means your valves won't collide with your pistons when they are open and the piston comes up (happens when the timing belt breaks).
-Rémy
02 SiR, 08 250R
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Basically it means that if you snap a timing belt while driving, you won't damage your internals (if it's not non-interference you can break/bend valves among other fun stuff).
post Oct 1, 2008 - 10:52 PM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE (GotToyota @ Oct 2, 2008 - 12:30 AM) *
May I add that "other fun stuff" includes a huge repair bill and a lesson learned laugh.gif
-Rémy
02 SiR, 08 250R
post Oct 7, 2008 - 2:50 PM
foutong
Joined Feb 6, '08
From portland or
ok so my buddy and i cranked it out and replaced the belt. now it makes a rinding noise when i rev, did i over tighten the belt or is that normal? and when i was doing the timing the notch was slightly to the right of 0 is that retarded or advanced?
post Oct 13, 2008 - 2:04 AM
3SGTE-auto
Joined Sep 13, '08
From Australia
QUOTE (foutong @ Oct 7, 2008 - 2:50 PM) *
Retarded??? It sounds like it's advanced but I'm not certain. I'm so so happy that the celica engines are non inteference - I too broke my timing belt last year. I got it fixed with new water pump by mechanic for $600 aus. Bit expensive but oh well... smile.gif
post Oct 14, 2008 - 12:37 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
i believe... and someone please correct me if I'm wrong, but I think that when the car is running and you are checking the timing with the timing gun, you should be around 10...
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Oct 14, 2008 - 4:50 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
if it is making that sound it could either be the accessory belt or the timing. which should have set at the org point.
when i replaced mine my accessory belt was too tight. so i adjusted the alternator to loosen it a bit. it still whine a tiiiny bit but not to a point of concern
エキサイティングカーレーシングチーム!
post Oct 14, 2008 - 8:41 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
get a new alternator and have it on hand, the bearings in your current one have been damaged by the overtightened belt.
post Oct 14, 2008 - 9:29 PM
rapidfire
Joined Jul 15, '07
From Mexico
i had same problem when i had my 90 celica st, my car just died when i was driving, and there was no spark, so i changed the distribuitor coil, and the car runs again!! but that celica have a electronic coil.
post Oct 14, 2008 - 10:16 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (Bitter @ Oct 14, 2008 - 9:41 PM) *
who me? when it was whining it was only for 2 minutes when i started the car after i put everything back together. then i loosened it. it is fine now. it probably whines for a little bit once a week
エキサイティングカーレーシングチーム!
post Oct 15, 2008 - 6:49 AM
trdproven
Joined Aug 2, '05
From Guam
If its your accessory belt, loosen it and then put some belt conditioner or belt dressing.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 15, 2008 - 10:44 AM
Random_Stranger
Joined Mar 20, '07
From Bakersfield, CA
I had no idea a car dying could be all these other things. Mine was doing that and I asked for a jump, died again within seconds as I began to drive. So I figured it was the alternator. Changed it, didn't have that problem again. But what the fellas are telling you, are also things to consider. I guess that is why it is always important to diagnos a problem before assuming it is 1 thing and trying to fix that. In case some of you out there do not fix your own car and take it to shops. Which there is nothing wrong with that at all by the way. I used to do that until I got ripped off but not everyone is dishonest.
Lo-Fi Version Time is now: November 23rd, 2024 - 10:51 PM
