> Mounting a 3sgte, what engine mounts do I need
post Sep 24, 2003 - 2:21 PM
95ST
Joined Jan 1, '03
From CT
In order to put a 3sgte into a 95 ST can I use the engine mounts that are part of the clip or buy GT mounts? Im not a confident welder so making my own would be a problem and I would like to have the best preperation going into the swap as possible.
post Sep 24, 2003 - 2:27 PM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (95ST @ Sep 24, 2003 - 12:21 PM)
Yes... use the mounts that come with the clip... the mounts on the passenger side is a direct bolt on. The driver side will need to be tack welded, unless you can some up with a better idea... or just decide to get one fabricated for that side...
Lo-Fi Version Time is now: December 1st, 2024 - 7:50 PM
