> 20 VALVE HELP, 4age mods/ sus
post Oct 4, 2008 - 1:55 PM
white97
Joined Sep 1, '07
From south carolina
I just got done doing my swap and of course a car can never be finished. so i was wondering if anyone who has or had a 4A, has any idea what type of aftermarket stuff to use. Mainly im wondering what kinda clutch and flywheel, cams, and other bolt on mods to go with. also i'm thinking about upgrading my suspension system soon, i was wondering if anyone could help with the right set up to go with for an ST?
post Oct 4, 2008 - 2:47 PM
lx130
Joined Sep 28, '07
From Skokie, Illinois
club4ag.com helps tons.....im planning on a 20valve swap too
'95 Celica ST Coupe. Love it.
post Oct 5, 2008 - 9:28 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
You can't really upgrade the cams, because it runs on VVT which requires the stock cams to work. You could remove the vvt cams but im not sure if the motor would leak oil or what. As far as Flywheel and Clutch goes you can use whatever works for the 7AFE and 4AGE 16v, since I've compared the 2 and they are pretty much identical to the 20V.
Not much bolt on for the 20V and if you wanted to run ITB's you need an aftermarket Fuel controller or ECU, or a BT ECU with some wire addons.
The Headers are also a tad different from the other 16V since you would have to grind or drill holes to mount it and make it fit.
If you want an aftermarket intake you would need to get an adapter plate for the AFM which you can find at some Auto Parts store or EBAY for cheap.
post Oct 6, 2008 - 1:22 AM
WH95TE
Joined Jun 16, '06
From Plantation, FL
Which 4a has the best aftermarket support?
post Oct 6, 2008 - 8:58 AM
turboecho2005
Joined Oct 2, '08
From Canada
I have a 4age 20v and in the end it really comes down to how much money you want to spend and how much hp you want to get...
the 4agze 16v is a turbo friendly motor and most people remove the supercharger and replace it with a turbo. The motors are CHEAP and the aftermarket support is pretty large.
the 4age 20v is a high compression motor so its not turbo friendly. to get some serious power out of it you need to get some forged pistons and rods. the blacktop is the better then the silvertop. It has larger ports on the head, lighter rods and came with an options 6 speed transmission. There is quite a bit aftermarket for the 20v motors but it seems like you'd have to get most of it from japan as they are not too popular motors in north america. There sell aftermarket cams but you'd lose the VVT ability... but thats ok since VVT is designed more for fuel efficiency then performance.
I'd recommend the 20v blacktop if you can afford to spend the money because ultimately it looks sick in the engine bay wink.gif but its really more for bragging rights since the 4agze can push as much power as the 20v and can be done on a budget.
but i don't know why people would want to swap a 4ag motor into a celica when you guys have WAY better options... i've been seriously contemplating putting in a 1UZ-FE into my celica in spring. Because it all comes down to displacement in the end....
Lo-Fi Version Time is now: November 26th, 2024 - 10:05 PM
