Enthusiast ![]() ![]() Joined Jan 9, '04 From Quebec city, Quebec, Canada Currently Offline Reputation: 1 (100%) ![]() |
I'm selling my turbo kit . I'm trying to sell the whole kit first don't ask me for the parts. You can see pics in my profile and I can post more at your request.
LIST ; -harcore 316 ss turbo manifold ceramic coated t3 (with bung for egt) -38 mm tial wastegate (polished) (8 lbs spring) -tubonetics t3 super 60 ceramic coated and polished (no shaft play) good to +/- 20 psi (rated at 350 hp) -spearco intercooler bar and plate -2.5 '' intercooler piping with all connect and clamp -440 cc injectors from 7mgte with clip (cleaned and blanced) -hks ssqv bov -oil lines for the turbo (in + out) -monster flow air filter + 3'' piping to the turbo -2.5 inch dowpipe (with bung for o2 sensor) + flex pipe Will bolt on on 6gc with 7a block + 4a head (7age) Will fit on 7afe with some mods Will fit on corolla fwd with some mods Dynoed last week at 200 whp on mustang dyno (equivalent to 230 whp on dynojet !!!) at 12 psi of boost. During the dyno session we obtain approx. 6 whp per lbs of boost. (started at 172 whp at 8 lbs) I had to stoped because of the costs (120$/h) but also of high intake temperature wich cause to mapping with very (ridiculus) low timming. The cause was too small dyno fan because I have much less temperature on street. I had no doubt this kit can make 300 whp with the right support mods. Cost to me 4500 $ , ask 2000$ + shipping . I can help you with some information but please don't waste my time ; i'm very in rush these days .... Kit is currently on my car but i can remove it quickly if needed. I can sell my engine management also ; autronic smc with cdi 500r(ignition) (one of the best I've experimented) + 7mgte coil pack. Cost 3900$ ask 2200$ (Just want to upgrade for another autronic model) Thanks Claude |
Some pics
![]() ![]() ![]() ![]() ![]() ![]() Claude |
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) ![]() |
good luck with the sale. the kit looks awesome!
This post has been edited by trd94: Oct 5, 2008 - 10:45 AM -------------------- ![]() |
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 18, '07 From Bergen county NJ Currently Offline Reputation: 24 (100%) ![]() |
Why are you selling this kit only a week after the dyno?
Do you have the dyno sheets? This question people will prob want to no. -------------------- |
I'm selling to upgrade .... bigger ....
Claude |
bump
Enthusiast ![]() ![]() Joined May 23, '06 Currently Offline Reputation: 0 (0%) ![]() |
What mods would be needed to be done to the 7afe to make this work?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
bump for a fellow 7agte
![]() good luck -------------------- yea your 3sgte is cool but ill stick to my 7agte
Enthusiast ![]() ![]() Joined Apr 22, '07 From Buckinghamshire, UK Currently Offline Reputation: 2 (100%) ![]() |
hey will the 440 injectors fit my 7AFE? if so dibs and how much?
What mods would be needed to be done to the 7afe to make this work? You will need appropriate engine management (greddy emanage style or stand alone type) change the flange on the manifold to suit 7afe head and maybe a little modification to the last section of intercooler pipe to bolt on throttle body. You will have also to fit the drain plug on oil pan and get a ''t'' fitting for the oil alimentation + oil pressure sensor. hey will the 440 injectors fit my 7AFE? if so dibs and how much? They are not for sold separate for now , I think they fit on 7afe but I need to have it confirmed ....anyone on this ? Claude |
![]() Enthusiast ![]() ![]() Joined Sep 2, '06 From Mechanicsburg, PA Currently Offline Reputation: 19 (100%) ![]() |
interested in wastegate if you do decide to part out
-------------------- '99 Celica GT - White
![]() Etak28 |
Lo-Fi Version | Time is now: February 19th, 2025 - 9:46 PM |
