2 Pages V  < 1 2
> FS raomdom stuff !, take a look !
post Oct 8, 2008 - 2:35 PM
Culpable04
Joined Apr 17, '06
From New Jersey
pics of the amps are up, not the greatest, iphone + me = failure lol but is actually a 1500 watts amp. tested and works great, something I have to point out is that is missing some of the screws that hold the wires, I had to improvise to test them. I'm sure you can get screws that will fit in place.
all paid orders are shipped.
post Oct 9, 2008 - 12:35 PM
Culpable04
Joined Apr 17, '06
From New Jersey
bump !
post Oct 9, 2008 - 12:56 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
Do you have a 2 way for the front subs? cause i could use one...=p
post Oct 9, 2008 - 1:01 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (Daftboy @ Oct 9, 2008 - 1:56 PM) *
two way what ?
post Oct 9, 2008 - 1:42 PM
Daftboy
Joined Jun 30, '06
2 channel amp for the speakers cause i need something for my front ones.
post Oct 9, 2008 - 1:48 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (Daftboy @ Oct 9, 2008 - 1:42 PM) *
the rockford forgate is a 2 channel amp, with built in cross over,
make me an offer.
This post has been edited by Culpable04: Oct 9, 2008 - 1:48 PM
post Oct 9, 2008 - 2:12 PM
Daftboy
Joined Jun 30, '06
can you get me a model number on that one so I can look up the specs?
post Oct 9, 2008 - 2:23 PM
Culpable04
Joined Apr 17, '06
From New Jersey
the model is 501s
these are the specs
* 125 watts RMS x 2 at 4 ohms
* 250 watts RMS x 2 at 2 ohms
* 500 watts RMS x 1 at 4 ohms in bridged mode
* stereo or bridged mono output
* 4-ohm stable in bridged mode
* Tri-Way capable
* requires 8-gauge power and ground leads and a 50-amp fuse  wiring and hardware not included with amplifier
* continuously variable 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
* MOSFET power supply and output devices
* MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
* TOPAZ  noise-killing differential inputs that eliminate 80% of ground loop noise
* Trans"ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
* NOMAD  advanced protection circuitry for "intelligent" shutdown protection
* wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
* speaker- and preamp-level inputs
* 12-1/16"W x 2-3/8"H x 9-7/8"D
* 1-year warranty
post Nov 3, 2008 - 10:16 PM
Culpable04
Joined Apr 17, '06
From New Jersey
Bump !
post Apr 28, 2009 - 5:15 PM
NewOrleans
Joined Jan 27, '09
From New Orleans
i know this is old but wondering if you still have mirrors and if i could get some pics
thanks
2 Pages V  < 1 2
Lo-Fi Version Time is now: April 20th, 2025 - 10:10 PM
