17 Pages V  « < 14 15 16 17 >
> awd rhd conversion complete, shes back on!!!!!
post Feb 2, 2011 - 11:42 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (pipes @ Feb 2, 2011 - 4:59 PM) *
well i guess i should update this with a status of the car...... this year i should be just doing little things on the car here and there
i am looking for the following things though any help would be great
1 exhaust since day one i havent gotten this fixed
2 bigger injectors anyone willing to part with a set of 800cc or higher injectors let me know
3 a standalone but this is where im inthe dark... i have an aem f/ic but i dont think it will help me where i need it with the cams
4 i need a tune i ve driving around on 9lbs of boost funny thing is at 9lbs the car is faster than it was before lol so that says something.... but i want to go to 24psi so.....
i need advise and help to get there and this forum is the place to do it
man! sounds good! i wish i could help you with the injectors, i was JUST talking to a friend that had some 850cc injectors that he was BEGGING another friend to take. he sold them earlier =(
for your power goals, aem standalone is where u cant go wrong, i keep hearing great things about it, but its pretty pricey, what are your power goals? i would ask lagos or manny, or pitcelica. theyve helped me ALOT.
post Feb 3, 2011 - 12:03 AM
chacha
Joined Dec 29, '05
From So-Cal
i thought pipes sold his car?
post Feb 3, 2011 - 1:29 PM
mkernz22
Joined May 10, '10
From MA
When you converted to RHD, did you extend the wiring front the left side to the right? or did you use the harness that came with the clips?
Also, do you have a step by step process or atleast some pictures?
post Feb 3, 2011 - 2:49 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (chacha @ Feb 3, 2011 - 12:03 AM) *
I had someone jerk me around for a week....and im the type of person as long as its still mine ill keep working on it
QUOTE (mkernz22 @ Feb 3, 2011 - 1:29 PM) *
Everything on my car is from the jap car.... I have like 3 pics if that.....im not really a big picture taker!! But ill try to help
post Feb 3, 2011 - 11:04 PM
chacha
Joined Dec 29, '05
From So-Cal
you mean they took it for a joy ride or spam you? lol, i didn't mean to offend you
post Feb 3, 2011 - 11:14 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (chacha @ Feb 3, 2011 - 11:04 PM) *
No offence... It takes cash to drive it...they jus came and wpanted to test drive... And i simply say i drive unless your gonna buy
post Mar 28, 2011 - 7:54 PM
pipes
Joined Apr 23, '08
From boston MA
well here are the updates spring is here!!!!
1 got factory sideskirts fresh from the bodyshop have to install maybe next week
2 replaced the center bearing on the driveshaft... cool thing is my bearing came from an 05 sienna
3. rebuilt my rear calipers cant figure out what color to paint them
4 next thing is to rebuilt the front calipers
5 still need a front pipe!!!
6 a tune and hopefully i hit the numbers i want
post Mar 29, 2011 - 10:39 AM
czwalga
Joined Sep 27, '10
From pittsburgh
Did you use the control arms from the GT4 or GT that attach to the stock body locations?
On mine, I used the GT4's which are about 3/4" shorter. However I was thinking now it makes the strut more on an angle due to the entire subframe being shifted forward a little. I'm debating if I want to drill new holes in the strut tower to accomodate the move.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Mar 29, 2011 - 4:57 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (czwalga @ Mar 29, 2011 - 11:39 AM) *
i used the gt4 arms...it aligned fine
post Mar 29, 2011 - 7:39 PM
jmeyer
Joined May 14, '08
From Grand Island NY
Same here used GT-4 arms attached to the GT body mounting location. Struts are almost perpendicular to the ground so if yours are angled there may be an issue.
1994 Supra TT
1999 Cadillac Escalade (winter ride/tow truck)
1994 Celica GT-4 Converted
1998 Celica GT-4 Converted
1987 Corolla FX
1986 Corolla AE86 (Next Project)
post Mar 30, 2011 - 7:41 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (jmeyer @ Mar 29, 2011 - 8:39 PM) *
Well the hub definitely moved forward a little by using the GT4 arms. I'm at work, but off the top of my head the GT4 hub will sit .5" closer to the front of the wheel well than stock. I dont think it's a big issue, but I spent hours aligning it properly. Then spent a few more hours aligning it after I realized the prop shaft had a CV joint and could sit higher. Then to get the correct angle on the subframe to make sure the u joint is at 0 degrees. So I really want to make sure everything is as perfect as it could be.
As of now I know it would be fine on the street, but i'm going to be beating on mine more than any street car will be so if theres any weak points i'll find them. I was just curious because it does change the angle of the strut.
This post has been edited by czwalga: Mar 30, 2011 - 7:55 AM
-10 F150
post Mar 30, 2011 - 11:02 AM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
I was in the Best Buy parking lot in Dedham a few months back and saw a celica with stock gt4 wheels...I was like...that's gotta be pipes...drove over to it and got out, saw the right hand conversion, stood around to admire it for about 15 minutes (was waiting for you to come out but you never did). So if you saw someone laying on the pavement looking under your car, that was me thumbsup.gif
post Mar 30, 2011 - 11:20 AM
pipes
Joined Apr 23, '08
From boston MA
Oh yeah... Proly earlier this month..... I just started driving it since the winter ended.....but hit me up if you wanna see it up close
post Mar 30, 2011 - 5:30 PM
Id like to know the difference on the gt4 arms vs St202 arms...my rear came with the arms cut frown.gif
If I can use my oem ones that'd be great.
post Mar 30, 2011 - 5:53 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (playr158 @ Mar 30, 2011 - 6:30 PM) *
Well you'd have to compensate on the driveshaft. It couldnt slide over the transmission splines as far, not that I'd think it would be a huge problem but something that would have to be accounted for.
-10 F150
post Mar 30, 2011 - 7:08 PM
well new arms can be purchased from FENSPORT i believe, pretty easily.
Anyone have a set of arms to measure up? since my GT4 arms are cut, i'm unable to do this.
post Mar 30, 2011 - 8:20 PM
pipes
Joined Apr 23, '08
From boston MA
H
QUOTE (playr158 @ Mar 30, 2011 - 8:08 PM) *
well i just put the car back into storage....so ill see if i can get back to check it out
post Mar 31, 2011 - 7:00 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (playr158 @ Mar 30, 2011 - 7:08 PM) *
I've already measured them, like i said its about .5". This is from hole to hole. The arms are actually about the same length, but the there is more material surrounding the hole on the GT4 arms. Hole to hole is what actually sets the distance though.
Honestly I think you could go with either and be fine, but you're just going to have to compensate with the drive/propshaft mounts. The subframe will sit back about .5" further if you use the GT arms versus the GT4.
-10 F150
post Mar 31, 2011 - 8:12 AM
post May 8, 2011 - 12:12 PM
pipes
Joined Apr 23, '08
From boston MA
hey guys i just got the rear calipers done....
im hoping to get the car back on the road within a week or 2...
just need a few more things and shes good to go
Lo-Fi Version Time is now: November 27th, 2024 - 12:55 AM
