awd rhd conversion complete, shes back on!!!!! |
Oct 21, 2008 - 11:00 AM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
I don't have any way to draw on the pic itself but it should be really obvious from this pic which type of weld I'm talking about. The one to the left of the red bit there is really really bad. It appears you may have forgot to open your gas valve due to the cavities visible even in these pics. Also it appears that it was not burned in very well but I can't really tell from here. You'd be surprised the difference between the forces exerted on those welds now vs what they will be when the car is on the road. If it were me I'd be making it as strong as possible and screw the weight [You've already added tons of that so make it right IMO]. Not coming down on your work at all - just trying to make sure you and the car stay as safe as possible. BTW - You have excellent taste in tires This post has been edited by DEATH: Oct 21, 2008 - 11:03 AM -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Oct 21, 2008 - 3:51 PM |
Enthusiast Joined Sep 8, '08 From Ireland Currently Offline Reputation: 0 (0%) |
Well Man SERIOUS RESPECT to you I apologise in advance but i will be howding you with questions the whole time man. The reason for that is i have an ST which im planning to make awd and putting in a 3sgte engine instead of my little 7afe engine. I have a full 92 gt4 shell with the engine and all the shafts and that. First question did you change over the gear shifter after new engine or the stock work for you.
Oct 21, 2008 - 3:52 PM |
I take it that shell is totalled or why would you do all that? Insurance scam LOL?
Oct 21, 2008 - 4:14 PM |
Yeah The shell is gone alright LOL would be wasting alot of time if not.
Oct 21, 2008 - 4:43 PM |
Well Man SERIOUS RESPECT to you I apologise in advance but i will be howding you with questions the whole time man. The reason for that is i have an ST which im planning to make awd and putting in a 3sgte engine instead of my little 7afe engine. I have a full 92 gt4 shell with the engine and all the shafts and that. First question did you change over the gear shifter after new engine or the stock work for you. the 5th gen celica rear end is narrower by a few inches. can you use the parts? prolly, but its gonna be narrower in the rear, than in the front, which i imagine will NOT be good for handling at all. lol and if you dont know which shifter you would use, you need to stop dreaming about the AWD swap, and start learning about these cars. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 21, 2008 - 4:54 PM |
Enthusiast Joined Apr 23, '08 From boston MA Currently Offline Reputation: 5 (100%) |
Well Man SERIOUS RESPECT to you I apologise in advance but i will be howding you with questions the whole time man. The reason for that is i have an ST which im planning to make awd and putting in a 3sgte engine instead of my little 7afe engine. I have a full 92 gt4 shell with the engine and all the shafts and that. First question did you change over the gear shifter after new engine or the stock work for you. the 5th gen celica rear end is narrower by a few inches. can you use the parts? prolly, but its gonna be narrower in the rear, than in the front, which i imagine will NOT be good for handling at all. lol and if you dont know which shifter you would use, you need to stop dreaming about the AWD swap, and start learning about these cars. I agree with pressure....well almost... I believe the axles are what makes it shorter... its the same rear so st205 axles may make up the inches you need |
Oct 21, 2008 - 5:01 PM |
can you use the parts? prolly, but its gonna be narrower in the rear, than in the front, which i imagine will NOT be good for handling at all. lol and if you dont know which shifter you would use, you need to stop dreaming about the AWD swap, and start learning about these cars. [/quote] Thanks for the advice appricate that but have made measurments and look into this for over a year before starting it and the stock can be used but no harm in having other opinions on the topic from people that would have a little more experience on the topic. |
Oct 21, 2008 - 5:05 PM |
Thats right pipes the shafts and rear dift will all work fine but you are right will have to get st205 axles to make up the difference which will have it all sorted.
Oct 21, 2008 - 5:37 PM |
from the pic, do you have enough clearance, it does not look like it, you barely make that 4 by 4. Seems like the axles are pointing downward instead of upward. I am no expert, but maybe thats ok. I was just pointing out. Make sure you weld it right. but in any ways, great job done -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Oct 21, 2008 - 5:53 PM |
from the pic, do you have enough clearance, it does not look like it, you barely make that 4 by 4. Seems like the axles are pointing downward instead of upward. I am no expert, but maybe thats ok. I was just pointing out. Make sure you weld it right. but in any ways, great job done Depending on wich picture.....the crappy ones ore the good ones? Some pics were with the car in the air others with the car lowered |
Oct 21, 2008 - 6:18 PM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
Well apparently I was a bit blunt in my previous post, sorry to you and Gman
congrats on the swap and awd. I was under the impression the entire 205 rear was going to be used. I hope it works out for you. -------------------- JDM guy made me do it.
Oct 21, 2008 - 6:39 PM |
Well apparently I was a bit blunt in my previous post, sorry to you and Gman congrats on the swap and awd. I was under the impression the entire 205 rear was going to be used. I hope it works out for you. Lol no biggie.... um it was used but we weren't going to cut into the whole car we used the spare tire section that wat the gastank could fit....we also use the floor for reinforcement.... but thanks for the support any question ask away... I'm leaving class now so messages will be forwarded to my phone.... yeah my phone has flash and internet lol |
Oct 21, 2008 - 6:52 PM |
My phone has GPS and Internet but no flash
Nice job, can't wait to see it all done! -------------------- |
Oct 22, 2008 - 12:48 PM |
Enthusiast Joined Apr 19, '07 From Dayton, Ohio Currently Offline Reputation: 7 (100%) |
edit
This post has been edited by boosted95: Jan 28, 2009 - 11:17 AM -------------------- |
Oct 22, 2008 - 1:47 PM |
Enthusiast Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
hes got aftermarket coilovers installed so im assuming he has it lowered quite a bit.. hence the little clearance under the car.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Oct 22, 2008 - 2:13 PM |
coilovers and reasonable lowering amount = \ _____ / look to control arms and axles...which is ok.
massive amounts of ground clearances is over rated...... if you can fit a key fob laying flat under your car .... being able to clear a 2x4 This post has been edited by playr158: Oct 22, 2008 - 2:15 PM |
Oct 22, 2008 - 3:53 PM |
coilovers and reasonable lowering amount = \ _____ / look to control arms and axles...which is ok. massive amounts of ground clearances is over rated...... if you can fit a key fob laying flat under your car .... being able to clear a 2x4 A key fob?? I'm not trying to rock crawl...... 2 credit cards flat now that's low |
Oct 23, 2008 - 6:07 PM |
Enthusiast Joined Oct 9, '08 From Hyde Park Currently Offline Reputation: 0 (0%) |
WoW thats amazing work...who did it and how much????
Oct 23, 2008 - 6:33 PM |
coilovers and reasonable lowering amount = \ _____ / look to control arms and axles...which is ok. massive amounts of ground clearances is over rated...... if you can fit a key fob laying flat under your car .... being able to clear a 2x4 A key fob?? I'm not trying to rock crawl...... 2 credit cards flat now that's low Key fob height (about 2" tall) (my jetta was this low, all though this is not my car/picture) (yes that is an OIL pan + tranny in the pic) This post has been edited by playr158: Oct 23, 2008 - 6:34 PM |
Oct 23, 2008 - 7:13 PM |
http://s163.photobucket.com/albums/t299/jo...nt=MVI_0446.flv
This is Driving around Hyde Park, have you seen it??? GT4 and RHD....WoWzer'z This post has been edited by DatGuyDatDidIt: Oct 23, 2008 - 7:20 PM |
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:26 PM |
