> Help?! How do I remove clutch master cylinder?
post Oct 11, 2008 - 4:31 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
It appears my clutch master cylinder went out. I've replaced the slave cylinder already, so that leaves the MC which I believe is back-bleeding; can somebody point me in the direction of where I might find removal instructions? Or give me a rundown on how to remove the MC? I'm picking up a new one today and intend/hope to install it tomorrow.
Thanks!
This post has been edited by GriffGirl: Oct 11, 2008 - 4:31 PM
post Oct 11, 2008 - 4:57 PM
First, undo the hard line on the engine bay side of the master cylinder (10mm). Use a flare wrench if you can.
Then, take a flashlight with you and lay in the footwell on your back with your head at the pedals.
There's a pushrod that comes out of the firewall (its part of the master cyl) and connects to the pedal. Take off the clip that holds in the pin at the pedal and undo it from the pedal.
Look at the clutch pedal bracket and you'll see two (12 or 14mm, I can't remember) nuts right behind the pedal on either side of the push rod. Then follow the bracket way up and there's another nut of the same size. I believe there is another one at the bottom but I can't remember since I think I found it while doing Tina's (ILuvMyCelica95) but mine (this is Stef/hurley97, not batman) doesn't have the bottom one.
Then you can pull out the clutch master cylinder.
This post has been edited by Batman722: Oct 11, 2008 - 4:59 PM
post Oct 11, 2008 - 9:45 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE (Batman722 @ Oct 11, 2008 - 5:57 PM) *
to edit what I wrote, you can just disregard that whole section in italics. Half of the times I've taken the master cyl out or put one in I was putting in the whole pedal assembly. Sorry smile.gif
This post has been edited by hurley97: Oct 11, 2008 - 9:45 PM
I <3 Dustin---07/16/06
post Oct 12, 2008 - 10:26 PM
GriffGirl
Joined Feb 7, '07
Okay, these instructions were perfect! It was a total cake walk - the hardest part was just getting up in there at those two bolts on either side of the push rod.
I'm still having the same problem w/the clutch though. Basically car won't go into gear w/the engine running. It goes into gear fine w/engine off, but when it's running 1st is not possible, 2nd requires a great deal of force, and so on. Reverse results only in a horrible gear grinding, so I'm not even gonna attempt to see if it'll go in reverse at all.
When I idle in 1st w/the car running and clutch in, after about 2 minutes the car will start to vibrate hard and will just get worse the longer it runs. RPMs drop too as vibrations increase; if I let it run long enough it will probably stall out. Oh, and there's no burning smell of clutch nor are there any strange noises.
Also, if I start the car in 1st and let up on the clutch as though to drive it, it'll pull forward as it normally should.
My initial thought (obviously) is that this is a hydrolic issue and while there were (and are) no visible signs of leaking, that somewhere it was back-bleeding. I've replaced the slave cylinder to no avail, and have now replaced the MC also to no avail.
Tomorrow I will bleed the system out again - it is entirely possible I didn't flush it properly after replacing the MC. I have two questions: 1, can someone please instruct me as to the proper way to bleed the clutch line? Pedal pressure feels good right now and normal, (pedal play feels correct too) but I'm trying to eliminate the hydrolic system as a cause. 2nd question is: anyone have any ideas as to WTF is going on w/my car?!? Why would the clutch seemingly not disengage? I looked at the synchros too, they appear pretty alright; one is a little wobbly and worn, but doesn't *appear* to be problematic. W/out ever having dealth w/this before, I have nothing to compare it to though.
Help (please)!
post Oct 12, 2008 - 11:25 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
If you pump the pedal or don't hold the clutch in for longer than you need to everything works like normal, right?
The RPMs dropping and vibrations is the hydraulic system not holding pressure and slowly disengaging the clutch. That sounds entirely like a clutch hydraulic system problem to me. I had the same issues before, I replaced both the slave and master at the same time.
You could try bleeding the system again, but if the pedal pressure seems fine that probably isn't the issue. It's just like bleeding brakes, open the bleeder at the slave cylinder and either 1. use a mighty vac to suck out the fluid while you add to the master cyl or 2. have someone pump the pedal and add to the master cyl until there are no bubbles and tighten the bleeder.
Did you use OEM parts? Aftermarket rebuilds could cause problems. I have an aftermarket rebuilt master cyl and slave and it's always felt a little wrong to me. Maybe you got a defective master cylinder? Start the car, hold the clutch in, and have someone watch the slave cyl to see if it starts to push the fork out slowly. If it does then you know the problem is somewhere between the pedal and slave cyl, which has to be within the hydraulic system.
This post has been edited by hurley97: Oct 12, 2008 - 11:27 PM
post Oct 13, 2008 - 11:38 AM
GriffGirl
Joined Feb 7, '07
I used new parts but not actual Toyota parts - IIRC both the master & slave are Raybestos, both new not rebuilt. It did occur to me that the MC is defective, but that seems like a bit of a stretch.
I'll do that with watching to see if the fork pushes out slowly. I'm a bit relieved to hear you still think it's a hydraulic issue too... (I'm also pleased to now know how to spell that word correctly, I knew something didn't look right! LOL)
Everything points to it being something w/the hydraulic system but it's just stumped me. The old fluid in the old MC reservoir was U-G-L-Y. There was a clear separation between the new fluid I'd added after doing the slave and the old fluid still in there - it was mirky and VERY brown and dirty.
Tonight I think I'm just going to attempt to bleed/flush the entire line until the fluid that comes out of the bleeder on the slave is clear. Maybe the old fluid just finally broke down and caused the failure of the old MC; between that and not properly bleeding the system I'm still having those issues.
Thanks for your advice/info - it's VERY much appreciated! I'll update this tomorrow with my findings. Hopefully it'll be after I've driven MYSELF to work instead of bumming a ride again!
post Oct 13, 2008 - 1:25 PM
DEATH
Joined Dec 19, '07
From tx
Are you keeping the area around the various parts and connections completely dry and clean? A slight leak can cause you to never get a good bleed, slow loss of pressure etc and the only way you'd know it is if you saw the leak gradually spread over clean parts. I'd hose that area down with carb cleaner, let it dry then work the clutch for a while to see if anything develops in addition to the checks Hurley mentioned above. Borrowing some type of speed bleeding system [IDK what for this hydraulic system cause I've never had any problems changing and bleeding mine] would eliminate any guess work or grey areas - how about that mechanic friend of yours? Maybe he/she has something.
This post has been edited by DEATH: Oct 13, 2008 - 1:25 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Oct 13, 2008 - 2:58 PM
GriffGirl
Joined Feb 7, '07
But yes, I'm keeping it clean, I know not to get debris in the MC or anything, plus I'm kind of meticulous about that sort of stuff anyway tongue.gif The engine bay is actually pretty clean, I cleaned it a few weeks ago and have kept it wiped down since then.
I'm gonna buy another bottle of brake fluid and bleed the clutch until what comes out is clear. At least then I'll know for sure that it's clean w/fresh fluid and properly bled too biggrin.gif
post Oct 13, 2008 - 6:35 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
The old fluid being really nasty could possibly have something to do with it, but I still think the pedal would feel strange if that were the case. It's easy enough to try it though. Make sure all your bolts and hard lines are tight, check that the flex hose isn't leaking or swelled, etc. But if you try that test and the slave cyl moves while holding the clutch all the way in, there's definitely fluid still bleeding past something.
The clutch system is bled the same way and with the same tools as the brakes.
post Oct 13, 2008 - 9:52 PM
GriffGirl
Joined Feb 7, '07
Bled the system out more tonight, but nothing. Still won't go into gear. Doesn't vibrate as hard when I start it up in gear and hold the clutch in (still vibrates abnormally hard but not quite as bad as before), and it won't stall out but I still can't get it into gear with the engine running. Oh and fork thingie by the slave cylinder stays put when engine is running and the clutch is held in.
I can force it into second w/the engine running but can't get it into first if I start in neutral.
And now, I want to throw up. WTF is wrong with my car? What do you guys think I should check next, linkage?
It's looking more and more like my next venture will be learning how to drop the transmission. I was SO hoping to avoid that!
Oh, and PS: it seems as of yesterday the battery won't hold a charge either. Coincidence? Probably, but makes ya wonder.
post Oct 13, 2008 - 11:05 PM
if you pump the clutch pedal does to go into gear ?
try changing your tranny oil, that should help.
post Oct 14, 2008 - 11:18 AM
GriffGirl
Joined Feb 7, '07
No, it doesn't go into gear if I pump the clutch pedal - I totally thought of that too.
I was wondering about the tranny oil; I'll change it but just for my own personal knowledge, wouldn't the oil have been changed when the new clutch was put in last year? Or do you not have to drain the transmission to change the clutch? I know for a fact that the mechanic who did the work last year cut corners because the owner of the car at the time didn't have a lot of money. For example, he had the engine replaced, but didn't change the timing belt... stuff like that. Nice.
post Oct 14, 2008 - 1:50 PM
DEATH
Joined Dec 19, '07
From tx
No you don't have to change the tranny lube to change the clutch. IMO you got one more trick before you gotta drop that tranny and that's do what Batman said and change the fluid. I have 3-4 quarts of syncromesh [What you want - trust me] in the garage. You can borrow it and just pay me back after you get over all of this so this will be a free test other than shipping [There is nothing illegal about interstate shipping of oil is there?]
EXT: WRC/TRD/404
post Oct 14, 2008 - 2:00 PM
GriffGirl
Joined Feb 7, '07
How much is the stuff? I might be able to scrape together enough for it tomorrow. That's what I was gonna try to get anyway biggrin.gif
post Oct 14, 2008 - 2:23 PM
DEATH
Joined Dec 19, '07
From tx
Somewhere between $10-15/quart IDK - call Autozone. I'm not worried about it Griffy - I got the stuff for my upcoming E153 swap which I still haven't gotten driveshafts built for and the tranny still hasn't gotten here so it's gonna be early next year probably before I do that. You have time.
BTW - whatever Autozone, PepBoy's or O'reilley's wants for it is all you'd eventually owe me - the price range above is from memory and I might be all wet - call them.
And no - I have no idea how many quarts you need for the ST's gearbox - I've only ever changed out "S" Series trannys.
EXT: WRC/TRD/404
post Oct 14, 2008 - 3:51 PM
GriffGirl
Joined Feb 7, '07
Oh... and worst case scenario, if my whole transmission is toast I'm going to seriously attempt to take advantage of it and see what kind of upgrade opportunity it might present LOL
post Oct 14, 2008 - 4:04 PM
DEATH
Joined Dec 19, '07
From tx
Six speed!!!!!!
EXT: WRC/TRD/404
post Oct 14, 2008 - 4:16 PM
GriffGirl
Joined Feb 7, '07
QUOTE (DEATH @ Oct 14, 2008 - 2:04 PM) *
Six speed!!!!!!
If I can find one that mates up to a 7A, that's exactly the route I'd want to go. Or at least LSD biggrin.gif
post Oct 14, 2008 - 4:23 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE (GriffGirl @ Oct 13, 2008 - 10:52 PM) *
QUOTE (GriffGirl @ Oct 14, 2008 - 12:18 PM) *
yeah that definitely doesn't sound like a hydraulic system problem then.
How many miles are on the tanny? Did it show any signs of failing before, like grinding or anything?
The C52 tranny takes about 3qts. I think dry fill is a little over 3qts so I usually get 4 just in case.
post Oct 14, 2008 - 4:31 PM
GriffGirl
Joined Feb 7, '07
No, no signs of failing before, none whatsoever. Reverse was sometimes a little fickle, but no, no grinding ever. No slippage, just no symptoms whatsoever! I'm gonna try bleeding it one more time, in case there's still air in the line. A mechanic I spoke to today said all he can think it is really would be a hydraulic issue; he's totally stumped too.
Oh yeah... miles on the tranny. You ready for this?
239,xxx. It's the original one. (but has been rock-solid since I got the car July '07)
Lo-Fi Version Time is now: November 30th, 2024 - 8:28 PM
