Wierd Starting Problem ** PLEASE HELP **, Car Sometimes starts sometimes doesnt - shuts off while driving |
Oct 14, 2008 - 12:35 AM |
Enthusiast Joined Nov 24, '06 From Kansas City Currently Offline Reputation: 2 (100%) |
For the past 2 weeks my car has been starting sometimes sometimes not. You can hear it turn over but it never completely starts.
** Replaced Distributor ** ** Replaced Ignitor ** ** New fuel filters ** Still getting same problem anyone have ideas. If this doesnt get fixed im going to sell the car please help me so I dont have to sell it. ** There is no spark to the plugs when it doesnt start ** This post has been edited by alaNi: Oct 29, 2008 - 10:43 PM |
Oct 14, 2008 - 12:40 AM |
check all ignition components, cap, rotor, wires, plugs, fuel pump. Computer box is usually at the tail end of all this if all don't succeed if not also sensors. Do an OBD test on your car, its pretty accurate since you have a pre ODBII car.
This post has been edited by trdproven: Oct 14, 2008 - 12:41 AM -------------------- 94 Celica GT
Oct 14, 2008 - 8:16 AM |
This post has been edited by alaNi: Oct 29, 2008 - 10:42 PM |
Oct 22, 2008 - 10:56 PM |
Oct 22, 2008 - 11:35 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Did you check your distributor cap and rotor? Maybe they are all done for and need changing. Maybe your distributor is going bad. You have a 94 so the coil is internally in the distributor itself. First do a compelete tune-up. change your ignition components with oem stuff. ie spark plugs, wires, cap an rotor. Its not a fuel issue, if you're not getting spark. It was a good idea for you to change out your fuel filter, but ignitor? They rarely go bad. I believe your distributor is going on you.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Oct 23, 2008 - 12:34 PM |
Oct 24, 2008 - 10:39 PM |
Oct 25, 2008 - 6:48 PM |
condensor? I told you distributor. Just take your dizzy out and have someone at autozone check the voltage.
Oct 25, 2008 - 7:15 PM |
If you have no spark, check to see if the coil is getting voltage sent to it.
If it is getting 12V, the coil is bad, if not either the ignitor, ECU or wiring is bad, or the ECU isn't seeing the engine turning over [bad dist or wiring]. -------------------- |
Oct 26, 2008 - 2:42 AM |
make sure your ignition coil is working if it isn't then ECU. But Id swap before buying one on ebay or here.
Oct 29, 2008 - 11:15 PM |
bump
Oct 29, 2008 - 11:25 PM |
where is the ecu located? thanks
This post has been edited by alaNi: Oct 29, 2008 - 11:25 PM |
Oct 29, 2008 - 11:39 PM |
Passenger side behind the carpet bottom left of the glove compartment. This mayb be stupid, but are your battery termnals on tight?
Oct 30, 2008 - 12:02 AM |
Oct 30, 2008 - 12:09 AM |
just unhook the Neg cable and pull the 3 plugs on the back of the ecu and take out the 10mm nuts holding the ecu in.
Oct 30, 2008 - 9:44 AM |
Is the ECU off a 94 camry 5sfe the same? Its automatic and my car is manual if that makes a difference
This post has been edited by alaNi: Oct 30, 2008 - 9:50 AM |
Oct 30, 2008 - 11:10 AM |
NO you need to find a manual trans 5sfe ecu.
Oct 30, 2008 - 11:38 PM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
For the past 2 weeks my car has been starting sometimes sometimes not. You can hear it turn over but it never completely starts. ** Replaced Distributor ** ** Replaced Ignitor ** ** New fuel filters ** Still getting same problem anyone have ideas. If this doesnt get fixed im going to sell the car please help me so I dont have to sell it. ** There is no spark to the plugs when it doesnt start ** when it turns over, try holding the gas pedal for like a minute, if this works culprit might be your idle control valve. clean it! -------------------- God made man....
Everything else... Made in China |
Oct 30, 2008 - 11:46 PM |
How can that be if he's not getting spark.
Oct 31, 2008 - 5:16 AM |
Lo-Fi Version | Time is now: December 2nd, 2024 - 7:13 PM |
