> Removing Exhaust Manifold, 2.2 5sfe
post Oct 17, 2008 - 11:10 PM
Remy
Joined Jan 25, '06
From MN
I'm having some problem taking out my exhaust manifold the bolts that are located on the bottom of the manifold are a !@$% to get off I got one off or will....it snapped off and I'm having problems getting to the rest of the bolts located behind on the bottom of the manifold is their a easier way of getting them off ?? And yes I do have the chilten and haynes manual for the car. Thanks kindasad.gif
Edit: I don't have a impact gun either.....
Edit 2: I'm trying to change my gaskets btw.
This post has been edited by Remy: Oct 17, 2008 - 11:17 PM
"To Protect And To Serve The Wealthy" -POLICE
post Oct 17, 2008 - 11:33 PM
99Celica
Joined Nov 1, '07
From Santa Barbara, CA
u could try some anti-seize, and then a longer cheater bar. Or you could take it to a shop and have them loosen the bolts for you, they might want like 20 bucks. I would replace them once you do get them out.
post Oct 17, 2008 - 11:59 PM
Etak28
Joined Sep 2, '06
From Mechanicsburg, PA
QUOTE (Remy @ Oct 17, 2008 - 11:10 PM) *
man i thought mine was tough, that sucks... a breaker bar did all those for me but the bottom o2 sensor was the worse on my manifold. it was 100 percent rusted on.
if your having that much trouble i would look into having someone with an impact gun do it, and make sure you put in new bolts when you put it back on
'99 Celica GT - White
Etak28
post Oct 18, 2008 - 12:29 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
spray lots of wd40 then go at it with a breaker bar. You'll get it.
94 Celica gt white (sold)
post Oct 18, 2008 - 8:52 PM
Remy
Joined Jan 25, '06
From MN
QUOTE (bccentaur3 @ Oct 17, 2008 - 11:29 PM) *
Thats what I did broke one of the head bolts I'm afraid I'll break the rest of them too.... kindasad.gif
post Oct 18, 2008 - 9:21 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Had a problem with a real bad bolt before, had to take it to shop where they had to torch it. Might be an option.
Lo-Fi Version Time is now: November 24th, 2024 - 4:44 AM
