gear ratio |
gear ratio |
Oct 21, 2008 - 4:14 AM |
Enthusiast Joined Jan 14, '08 From UAE Currently Offline Reputation: 0 (0%) |
hi everybody.. i want to ask about the difference between 3sfe gear ratio and 3sge gear ratio??
can anyone tell the difference? PLZ I need help waiting for replays .... -------------------- |
Oct 21, 2008 - 10:21 PM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
Well the gear ratio comes from what tranny is bolted up to them.
-------------------- 1999 Celica GT
Oct 22, 2008 - 5:52 AM |
thanx bro
i used 3sfe manual trans with 3sge beams redtop....(3sfe trans for Gen 3 celica) so i want to know the difference in the gear ratio between 3sfe and 3sge beams redtop. because maybe the gear ratio effects in the power that come out from the engine i hope u get my idea ^_^" -------------------- |
Oct 22, 2008 - 6:07 AM |
why'd you use a 3sfe trans when the 3sge trans works?
Oct 23, 2008 - 5:20 AM |
becoz the 3sge trans is automatic..
so i used my manual trans which is for 3sfe -------------------- |
Oct 23, 2008 - 8:29 AM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
i used 3sfe manual trans with 3sge beams redtop....(3sfe trans for Gen 3 celica) 3rd gen is RWD so I doubt you used that - I think you must mean 4th gen. We'd have to know the series number of the trans and possibly the exact donor vehicle as well. BTW - There is alot more than gear ratios that you loose from the BEAMs trans - it also has LSD and bigger drive shafts. I'd def try to source an E153 with LSD for this application. This post has been edited by DEATH: Oct 23, 2008 - 8:30 AM -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Oct 23, 2008 - 9:05 AM |
Automatic 3sge transmission is the A140E.
1st - 2.810:1 2nd - 1.549:1 3rd - 1.000:1 4th - 0.706:1 Rev - 2.296:1 and i believe the manual 3sfe tranny will be one of the S series transmissions 51 * First Gear: 3.538:1 * Second Gear: 1.960:1 * Third Gear: 1.250:1 * Fourth Gear: 0.945:1 * Fifth Gear: 0.731:1 * Reverse Gear: * Final Drive: 3.944:1 53 54 * First Gear: 3.285:1 * Second Gear: 1.960:1 * Third Gear: 1.322:1 * Fourth Gear: 1.028:1 * Fifth Gear: 0.820:1 * Reverse Gear: 3.153:1 * Final Drive: 4.176:1 (EU Versions have a 3.944:1 Final Drive) This post has been edited by playr158: Oct 23, 2008 - 9:07 AM |
Oct 31, 2008 - 11:48 AM |
Enthusiast Joined Jun 1, '08 From STL Currently Offline Reputation: 0 (0%) |
S53
3.285 2.041 1.322 1.028 0.82 3.74 |
Nov 2, 2008 - 10:35 AM |
Anyone have multiple S54 ratios? I've had 3S-FE and 3S-GE both with S54, FE ('95 ss1,st202 ) had S54-04A and GE ('96 ss3 with lsd, st202, not beams) has S54-06D.
The 06D is more revvy than the 04A. -------------------- Mike W
Nov 3, 2008 - 2:48 PM |
Anyone have multiple S54 ratios? I've had 3S-FE and 3S-GE both with S54, FE ('95 ss1,st202 ) had S54-04A and GE ('96 ss3 with lsd, st202, not beams) has S54-06D. The 06D is more revvy than the 04A. Wouldn't that be more a function of engine power? We are talking about the FE versus the GE in conjunction with two slightly different versions of the same tranny.........so you have two variables here. Even if the FE and the GE had the same HP, it would be entirely conceivable that the flywheel on one engine was lighter than the other. But these engine don't have the horsepower; The GE has more and, if my memory serves me correctly, the 3SFE in all incarnations had a heavier flywheel. I've also thumbed through BGB RM380E a number of times and nowhere in the S54 section does it make any mention of it having different gearing versions. So just to take a random stab at an answer I'll go ahead and attribute the "revvy" 06D to having access to a more powerful engine. Any takers? This post has been edited by RedRkt01: Nov 3, 2008 - 2:51 PM |
Nov 4, 2008 - 4:16 AM |
I know the GE is more powerful, But what I meant by "revvy" is that cruising RPMs are higher in the GE's S54 than they are in the FE's S54
Eg, at 100KM/H aka 60MPH, My RPM in 5th gear in the FE was only a fraction higher than the 3K mark, In the GE the RPM is closer to the 3.5K mark -------------------- Mike W
Nov 4, 2008 - 8:51 AM |
I know the GE is more powerful, But what I meant by "revvy" is that cruising RPMs are higher in the GE's S54 than they are in the FE's S54 Eg, at 100KM/H aka 60MPH, My RPM in 5th gear in the FE was only a fraction higher than the 3K mark, In the GE the RPM is closer to the 3.5K mark Final drive. LSD or not would make the difference. |
Nov 4, 2008 - 6:36 PM |
Enthusiast Joined Jan 13, '08 From Christchurch New Zealand Currently Offline Reputation: 0 (0%) |
Yea its definitely in your final drive. my s54 at 100km is just over 3k aswell.
-------------------- 1994年 トヨタ 神々しい My Facebook My Bebo QUOTE (loll6g @ Nov 6, 2008 - 5:53 AM) automatics are for lazy ass drivers who jst want there car so that they can look cool |
Nov 17, 2008 - 4:51 AM |
Enthusiast Joined Nov 14, '08 From Hong Kong Currently Offline Reputation: 0 (0%) |
Check your ECU, if it's a A/T ECU, try to find a M/T ECU,they are different. genuine parts No.#89661-2G080, I have the same problem before and this is my scound gear box,but there is no changes, finally I plug a M/T ECU on , the problem is gone.
Nov 17, 2008 - 1:57 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
^^hmm when im at 100km/h im exactly at 3k ??
Nov 17, 2008 - 5:20 PM |
^^hmm when im at 100km/h im exactly at 3k ?? When i say just over its about a needle width, could just be error in the speedo either way. -------------------- 1994年 トヨタ 神々しい My Facebook My Bebo QUOTE (loll6g @ Nov 6, 2008 - 5:53 AM) automatics are for lazy ass drivers who jst want there car so that they can look cool |
Lo-Fi Version | Time is now: November 27th, 2024 - 7:11 PM |
